Eeprom dump thread!
This is a sticky topic.
  • Farasa
    • Jul 2016
    • 47
    • South-Africa
    #1021
    Re: Eeprom dump thread!
    Hi..
    I'm looking for firmware for a JVC 50 inch led tv...I don't have a number but a board number
    Chassis:Jug7.820.1222
    Cpu. :MSD6328 BXA-Z1
    Panel. :T546hb01
    54T07-c02
    Any help will be appreciated
    • Farasa
      • Jul 2016
      • 47
      • South-Africa
      #1022
      Anyone have this file
      • cheeky2
        • Dec 2012
        • 337
        • uk
        #1023
        Unlikely to get a response where the model number of the TV is omitted.
        • Retrocomputer
          • Aug 2012
          • 47
          • Italy
          #1024
          Originally posted by Retrocomputer
          First of all, thank you so much!!
          There's just one thing bothering me... The dumps you sent me are from a 19" TV, whereas mine has a 22" panel. Is it ok anyway?
          Thank you
          Davide
          No ideas about this? Or the best thing is just to try?
          Thanks!
          • lotas
            • Jan 2016
            • 4668
            • Russia
            #1025
            Thanks!
            Try, only save your dumps. First try spi flash (EN25F80) to check
            Here is another 22
            • Rajnhl
              • Oct 2018
              • 94
              • India
              #1026
              Thank you
              Davide
              if resolution is same than it will work.some settings like mapping may be needed in service menu
              • bader
                • Sep 2021
                • United Arab Emirates
                #1027
                Thanks a lot
                • Amazig
                  • Jul 2021
                  • 10
                  • Portugal
                  #1028
                  Re: nevir :nvr-7409-43hd-n
                  good night
                  does anyone have the dump of this tv,
                  main board: tp.s506.pb801
                  display: HV430FHB-N40
                  the TV only changes the color of the LED monitor, from red off to green on, and the only thing that does
                  thanks to anyone who can help even with an idea
                  thanks.
                  Last edited by SMDFlea; 09-20-2021, 07:12 AM. Reason: https://translate.google.com
                  • andrewc
                    • Apr 2015
                    • 18
                    • australia
                    #1029
                    Anyone has Sony 65W850C dump file?
                    • Rajnhl
                      • Oct 2018
                      • 94
                      • India
                      #1030
                      Originally posted by Amazig
                      boa noite
                      alguém tem o dump de este tv,
                      placa principal : tp.s506.pb801
                      display : HV430FHB-N40
                      o televisor só muda da cor de led monitor ,de vermelho desligado ao verde ligado, e a única coisa que faz
                      obrigado a quem pode ajudar mesmo com uma ideia
                      obrigado.
                      check back light
                      verifique a luz de fundo (google translation)
                      • Amazig
                        • Jul 2021
                        • 10
                        • Portugal
                        #1031
                        Hello
                        thank you rajnhl; I've already checked the bottom leds; everything working; now an information; I received the bin file to update via usb, will it be possible to record on the chip, because the tv does not turn on!
                        thanks
                        • tech9pc
                          • Sep 2021
                          • 49
                          Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
                          I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which has lost its HDMI port signals won't work.
                          They are practically identical. Anyone know if I flash the 7.T3458HA1000.0003 board with the 7.T3458HA1000.0008 firmware should work? Thanks for any help.
                          Board BD_CV3458H_A_10
                          Panel LC650RU1A
                          • andrewc
                            • Apr 2015
                            • 18
                            • australia
                            #1033
                            I need dump file for Sony 65W850C please.
                            • Rajnhl
                              • Oct 2018
                              • 94
                              • India
                              #1034
                              Hello
                              thanks
                              plug usb drive and connect to power .
                              • Farasa
                                • Jul 2016
                                • 47
                                • South-Africa
                                #1035
                                Hi..
                                I'm looking for firmware for a CHANGHONG LED55A4000 55 inch led tv...
                                CHANGHONG LED55A4000,
                                Panel. :T546hb01
                                54T07-c02
                                • ducky29
                                  • Dec 2015
                                  • 370
                                  • Europe
                                  #1036
                                  Hi..
                                  Panel. :T546hb01
                                  54T07-c02
                                  Post a picture from the back of your tv.
                                  • Farasa
                                    • Jul 2016
                                    • 47
                                    • South-Africa
                                    #1037
                                    Ok Ducky29
                                    • Jbeni
                                      • May 2014
                                      • FRANCE
                                      #1038
                                      Re: Polaroid TV switch off after logo display
                                      I am looking for the Dump Firmware of this model.
                                      Mark: Polaroid
                                      Model: TQL39R4PR001
                                      Main board chassis: CV9203H-A42
                                      LCD Screen / Panel: T390xvn01
                                      More information: W25Q32
                                      thank you for your reply
                                      • tachiouine
                                        • Nov 2018
                                        • 32
                                        • maroc
                                        #1039
                                        plase dump sony kdl19s5700
                                        • tech9pc
                                          • Sep 2021
                                          • 49
                                          Help! BD_CV3458H_A_10, 7.T3458HA1000.0008
                                          C/N: SU-CU-20180601
                                          Panel LC650RU1A or LK650RA1A01 ?
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
