Eeprom dump thread!
This is a sticky topic.
  • Samkville
    • Aug 2020
    • 6
    Re: Eeprom dump thread!
    Hello, I hope someone can help. I need EEPROM dump for Sony TV XBR-75X940D. Main board BM1 # 1-980-833-11 (173611611) dump needed for IC9017 (PIC16F527-I/SS) It is 20pin IC SSOP20. your help will be highly appreciated.
    • cangaro2
      • Jul 2021
      • spain
      #1002
      Originally posted by lotas
      finlux_40flhz274sc
      • zdenekc
        • Aug 2021
        • Czech Republic
        #1003
        i need firmware for Toshiba 24W3753DG TV
        Board: 17MB110P-pn 23451047
        LCD: VES236WNTC-2D-N01
        The TV only flashes red and green. Do you have recovery software for the specified TV? If possible, the installation procedure.
        I can't find anything: - ((((
        • Steve007iii
          • Aug 2021
          • Costa Rica
          #1004
          i need firmware for RCA 32
          Board: TP.MS3393.PB855
          • lotas
            • Jan 2016
            • 4598
            • Russia
            #1005
            What's the problem with the TV?
            Post your non-working firmware dump here.
            • Steve007iii
              • Aug 2021
              • Costa Rica
              #1006
              TV starts normally when put in Smart mode TV shows this ...
              TP.MS3393.PB855
              I need the firmware if anyone has them please
              ⚠ This Firmware is damaged ⚠
              Non-working firmware dump: https://www.mediafire.com/file/pm7ri...6S-SM.BIN/file
              32 inches
              modelo: RCA32A16S-SM
              • lotas
                • Jan 2016
                • 4598
                • Russia
                #1007
                Your software is fine, I cut off the eeprom now try to write it down
                if it fails, replace the SPI Flash with a new one.
                • lotas
                  • Jan 2016
                  • 4598
                  • Russia
                  #1008
                  TP.MS3393.PB855
                  32 inches
                  Does the TV itself support Smart?
                  He then had to have NAND or EMMC memory.
                  • Steve007iii
                    • Aug 2021
                    • Costa Rica
                    #1009
                    NAND GODDAMN!!!
                    it also has an android subsystem
                    Not everything is lost
                    someone in this forum was asking for this firmware for this board, there it is tested and working
                    Originally posted by javox
                    hola , me prodran ayudar con el firware de la pantalla cobia TP.MS3393.PB855 se los agradecere mucho. salu2
                    Originally posted by aquilesy
                    Hi, please your help, I need eprom dump for TV RCA Model RC4001-A board Nro TP.MS3393.PB855
                    32 inches
                    Model: RCA32A16S-SM
                    https://www.mediafire.com/file/5r88m...nches.rar/file
                    • lotas
                      • Jan 2016
                      • 4598
                      • Russia
                      #1010
                      The firmware on your TP.MS3393.PB855 is ok, you need to look for the usb firmware on the android module or somehow enter recovery and do a reset.
                      • medoali
                        • Jul 2020
                        • cairo
                        #1011
                        i hope some one can help
                        i need dump for Soniq L32V12A 32" LCD
                        thanks
                        • medoali
                          • Jul 2020
                          • cairo
                          #1012
                          thanks
                          main board ST306PT-T7
                          • giosat
                            • Jul 2021
                            • 5
                            • italia
                            #1013
                            Ciao
                            Tv lg47le5308
                            Main. Eax61766102(0)
                            Pannello lc470EUH
                            • Öğretmen27
                              • Oct 2019
                              • 36
                              • TÜRKİYE
                              #1014
                              Zenon ZN-AHD-5016 software
                              Zenon ZN-AHD-5016 software is needed. 25L12835F used. Fault: The device is stuck in the text zenon. There are all voltages.
                              Mainboard: GM8210-AHD-16CH
                              Flash ıc: 25L12835F
                              • zanskis
                                • Mar 2016
                                • Lithuania
                                #1015
                                hi.
                                i need emmc dump
                                sony
                                kd-49xe8096
                                main
                                1-981-326-12
                                (173633712)
                                GN3TR
                                thank you
                                The TV turns on and shows only the SONY logo.
                                I found
                                KD-55XF7596
                                KD-43XF7596
                                nothing changes, after resetting it needs to be refreshed via usb, and again only the SONY logo
                                • shuma66
                                  • Aug 2021
                                  • Egypt
                                  #1016
                                  Originally posted by Snazzysmith
                                  Sorry didn't make notes on board number.
                                  Please I need LG 42LB5RT eprom firmware
                                  • shuma66
                                    • Aug 2021
                                    • Egypt
                                    #1017
                                    ٍٍSony BRAVIA® KDL-40EX500
                                    System Software Update (version 1.514)
                                    May Be Useful and Help
                                    • cheeky2
                                      • Dec 2012
                                      • 337
                                      • uk
                                      #1018
                                      Originally posted by bboykes
                                      hi anyone got digihome 40272sm eeprom Vestel 17IPS71
                                      You give the model of the power supply without giving any details of your screen or your main board. Unlikely anyone would be able to help you with the lack of information supplied.
                                      • shuma66
                                        • Aug 2021
                                        • Egypt
                                        #1019
                                        Thank you
                                        • Shotgun25
                                          • Feb 2014
                                          • 90
                                          JVC LT-50C550
                                          UK model 55" TV
                                          Screen - V500HJI-PE8
                                          PSU - TV5001-ZC02-01
                                          Main - MSDV3255-ZC01-01
                                          TCON/Panel - Innolux V500HJI-XRME1 / V500HJI-PE8
                                          NAND - Toshiba TC58NVG1S3HTA00
                                          From a working TV that had LED backlight strips replaced.
                                          No password, 2 part rar.
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
