Hi I need dump for sharp LC-40LE730E SPI Winbond 25x20BVNIG
Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
added the zip file from this link for easier accessAttached Filesif you find these attachements useful please consider making a small donation to the site
Toshiba Models 26HL47, 32HL67U, 37HL67, 40RF350U, 42HL117, 42HL167, 42LX177, 46LX177, 47HL167, 52HL167, 52LX177, 57LX177
2007 LCD TV Seine Update
These TVs are known to have a problem turning on, this may be your fix.
Be sure to download and read the directions.
You will have to get your TV to turn on so if it will not turn on try resetting it. I unplugged my TV for about 10 minutes and when I plugged it back in I had to wait 2 more minutes and the TV turned on. Then I inserted the SD card and the update started. I used a 2GB SD card. Bigger SD cards may not work.Attached Filesif you find these attachements useful please consider making a small donation to the site
Bush 40"
MODEL: LE-40GCL-A-W
BOARD: TP.SIS231.P83
LOCATION: U5 - 25q64bAttached Filesif you find these attachements useful please consider making a small donation to the site
17mb35-4 flash dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi. looking for flash dump for Bush 40" led 17MB95M board and VES400UNVS-NO1 panel.
SPI flash MX25L1605D.
Thanks.Comment
Hi.I'm hoping to find the dumps I've got on another computer and post here just to contribute.Comment
please try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks turkay06, I will try it and let you know, even that the file name is 17mb95s and not the 17mb95m i have?Comment
Hi everyone, please find some of the flash dump files i managed to read from tv s (many of them don't have a reference to the main board- sorry), but most if not all should work.
good luck.Attached Filesif you find these attachements useful please consider making a small donation to the site
Some more flash dumpsAttached Filesif you find these attachements useful please consider making a small donation to the site
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
