Bush LCD52786F1080P
  • jmh474
    • Aug 2016
    • 46
    Bush LCD52786F1080P
    Hi again, so iv got another tv to play with, im at a bit of a loss to whats going on really yet again, i think its the T-con card but im not to shore is there any way of proving this, my problem is the TV stays on sometimes then other times it will just shut down. any help will be grate
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Bush LCD52786F1080P
    Another shit thread, no info for us at all.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by reeceyburger123
      another shit thread, no info for us at all.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Can you post pictures of your boards, clear and in focus.
        Have you measured any of the voltages on the power supply board.
        There's usually a printed legend on the board so if you could give the legend name and voltage read for each pin of the connector then that would be a good starting point for others to offer assistance.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Originally posted by Andrew F. Ali
          Doing my head in now, cant help if they dont help us.
          • diif
            • Feb 2014
            • 6978
            • England
            Maybe replace the batteries in your crystal ball telescope
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Only if Op buys them people like him are the ones draining them
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Op get us some pictures of the psu & tv please.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  If we had crystal balls we could see ourselves coming--which would be 'grate'...
                  (Some threads are an exercise in mis-use of a spell-checker!)
                  TELEFIX
                  • petehall347
                    • Jan 2015
                    • 4422
                    • United Kingdom
                    i dont think its the tcon ..
                    take the batteries out of the remote control to rule it out
                    • jmh474
                      • Aug 2016
                      • 46
                      hi really sorry for taken so long to get back iv had a few family issues, so as i said the tv works fine then just shuts off and no its not the remote lol,
                      • jmh474
                        • Aug 2016
                        • 46
                        hi really sorry for taken so long to get back iv had a few family issues, so as i said the tv works fine then just shuts off and no its not the remote lol, here are some pics of the boards, one problem is there is no legend to go by for readings so where do i begin
                        im getting a steady
                        24v
                        3.5.v
                        12v
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          here is the psu scematic although these can and do vary it should be ok for testing the voltages etc if you can test the tv in the working condition and when the tv goes off we should be able to tell what voltages are then missing
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            When you say it shuts off, does it go into standby, switch off completely or do you just lose the picture.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ok right Vestel Psu, could be cold solder joints or even failed Polly film caps causing the set to power down. Also sorry to hear, dont take what I say here personally.
                              • hollandd4@sk.com
                                king tut
                                • Feb 2017
                                i had this make and same problems changed t-com and motherboard
                                On luck so i looked at tv tube strips and they had came loose
                                Have a look
                                • FlailingEngineer
                                  Help with Bush Tv (Vestel 17mb95m Mainboard)
                                  by FlailingEngineer
                                  Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                  Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                  05-31-2023, 06:52 AM
                                • tyler123456
                                  Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                                  by tyler123456
                                  Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                                  I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                                  I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                                  Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                                  Anyone...
                                  08-16-2024, 12:51 PM
                                • Johnny.p
                                  Bush WI-1810 Internet Radio
                                  by Johnny.p
                                  I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
                                  U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
                                  11-25-2023, 04:18 AM
                                  Phase Loss Monitor having false triggering ( bad capacitors issues)
                                  by sam_sam_sam
                                  These phase loss monitor modules have two boards one board is basically the power supply board the other board is basically the phase loss monitor circuit
                                  It has three capacitors on it one on the power supply board 470uf@50volts (KMG) 0.11 ESR value
                                  The other two capacitor are on the phase loss monitor circuit board
                                  One capacitor is 10uf@63volts (Unknown brand) replacement capacitor automotive grade low ESR
                                  One capacitor is 100@50volts ( unknown brand) replacement capacitor was 100uf63volts automotive grade low ESR
                                  The results of the ESR are...
                                  06-07-2020, 06:48 AM
                                • razzer05
                                  Bush LE50GY15M - Firmware needed, Please!
                                  by razzer05
                                  I did a silly thing and tried to update the tv (Bush LE50GY15M) with a "allupgrade_6308rtbm.bin" off the internet with the same board name "T.MS6308.U701" and it now no longer works.
                                  I have researched quite a bit since Fridays messup, I've gathered a bit of information and tried multiple "allupgrade_6308rtbm.bin" files off the internet to try and fix it.
                                  The information I've come up with:
                                  A possible clone of "SEIKI SE50UO01UK" with a Bush Logo
                                  The board is as mentioned: "T.MS6308.U701"...
                                  09-23-2020, 03:43 PM
