Need help identifying an IC chip on a Bush DAB radio (BD-1801)
This topic has been answered.
  • tyler123456
    • Jun 2024
    • 7
    Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
    I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
    I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
    Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
    Anyone got any clues please?
  • Answer selected by tyler123456 at 08-18-2024, 05:29 AM.
    stj
    • 31260
    thats got paint on it.
    clean it with acetone.
    the ground pads make me think it may be a 9pin device with a pad under it.
    btw DAB is shit - i dont know why people buy into it.
    if you scan the DAB signals with an sdr reciever you find the data rates are so low it's hard to belive it's even understandable.
    32k or less for most channels.
      • 31260
      • tyler123456
        • Jun 2024
        • 7
        Thanks stj - I'll give it a try.
        • tyler123456
          • Jun 2024
          • 7
          Think I've got it... Not easy to read, but I think it's 8871E. Thanks very much.
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Loki_Fido
            Requesting help identifying chip in Macbook Pro A2485
            by Loki_Fido
            Hi ya folks,
            I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
            It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
            I replaced it and the SSD are fine. No more shorts.
            But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
            But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
            Chip marking...
            08-07-2025, 10:17 PM
            Common SPI bios chip programming Questions and Answers
            by SMDFlea
            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
            A: If you can`t read from it how do you expect to write to it ?.
            Q: Why is my bios chip unreadable ?.
            A: The programmer is faulty or has a worn or broken zif socket.
            The USB cable is frayed,connector pins worn or some other physical damage.
            Not enough amperage or voltage to power the programmer properly.
            Bad...
            09-02-2021, 04:40 PM
          • trepachka
            Help identifying this chip for Yoga 7 16IRL8
            by trepachka
            This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
            A photo of the chip is attached.
            Thank you....
            06-22-2025, 11:13 PM
