Phase Loss Monitor having false triggering ( bad capacitors issues)
    • Jul 2011
    • 6039
    These phase loss monitor modules have two boards one board is basically the power supply board the other board is basically the phase loss monitor circuit
    It has three capacitors on it one on the power supply board 470uf@50volts (KMG) 0.11 ESR value
    The other two capacitor are on the phase loss monitor circuit board
    One capacitor is 10uf@63volts (Unknown brand) replacement capacitor automotive grade low ESR
    One capacitor is 100@50volts ( unknown brand) replacement capacitor was 100uf63volts automotive grade low ESR
    The results of the ESR are as follows 0.70 this was a very low value for this capacitor compared to a new one
    The other value was 1.7 this value was very close to a new one but I do not remember which value went to which capacitor I am sorry about this
    Will test this phase loss monitor tomorrow at work and see if it works correctly or not
    Here is the website link where I buy these modules
    https://www.grainger.com/product/ICM...chQuery=icm408
    One interesting thing that is in the data sheet it says that it can operate at a temperature of 149*F really one of the capacitor was only rated at 85* this is why I went with automotive grade capacitors except one of them I did not have the power supply board capacitor in that grade on hand
  • redwire
    • Dec 2010
    • 3907
    Re: Phase Loss Monitor having false triggering ( bad capacitors issues)
    It would nice to see pictures of the inside of the module. It must use a small mains power transformer?
    I repaired a simpler phase loss detector and I think it was damaged from spikes 480VAC monitor circuit, cmos IC got zapped. Yours has so many trimpots.
      • 31015
      philips and rubycon make some 135' caps for use in stuff like boiler ignition boxes that get cooked.
      • redwire
        • Dec 2010
        • 3907
        Nichicon also has some new solid polymer capacitors to 125°C/257°F or 135°C/275°F or 150°C/300°F. But that is where plastics melt and most wire is only rated well below that. The league of teflon wire/pcb and special semiconductors.
        At high temps and many years, I find electrolytic capacitors usually dry out, but the Philips blue ones short. So C value goes down and ESR goes up.
        Lifetime is halved operating every 10°C above 40°C/104°F, according to Nichicon.
          • Jul 2011
          • 6039
          Well the phase loss monitor was reinstated and worked very well for 8 hours today
            by momaka
            03-15-2023, 10:17 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
          • Rick_1234
            by Rick_1234
            Good evening, gentlemen.
            Things I tried
            06-22-2024, 04:44 PM
            Wise Wing F199 19'' LCD monitor - recapped
            by momaka
            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
            When I saw the Craigslist post, I wasn't...
            08-24-2020, 10:58 AM
