Issues leading to the loss of 1.8V EN on the RX5700XT graphics card
  • conghuyms
    • Apr 2022
    • 58
    • Vietnam
    Hello everyone.
    I’ve seen many questions related to the 1.8V EN power rail on the RX5700XT graphics card. Could everyone help gather and summarize the different cases where this power rail is lost? This would help members and readers more easily troubleshoot and fix similar issues on their own cards in the future. Thank you all!
    As for me, I encountered this issue when the 1.8V EN rail was lost due to a faulty transistor Q10021. Are there any other possible cases?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3630
    • slovakia
    just look at simmilar schematic. there are MANY faults that can happen on this signal
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • lefetylorant
      Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
      by lefetylorant
      Hello Everyone,
      Long story short, I got this unit for very cheap.
      I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
      I've performed some measurements:
      - 20V rail perfectly...
      09-14-2023, 05:05 AM
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
    • benwaterson
      Main rail / charging circuit issues on Bucky/BenSolo 17859-1 board from Dell Vostro 5581
      by benwaterson
      Hi All
      Been a while since I have been here, and a bit rusty.
      I have the above laptop motherboard that was working and now the charging circuit is faulty.
      Have 19v in fine until it hits PU4403 - not shorts I can see and thermal cam reveals nothing.
      I have swapped out the ISL9538 and also the two mosfets (PU4403 and PU4405). Have 2.8v at the power switch, which pulls low when pressed - charging light comes on and goes straight off
      Below are measurements (pin names are per the datasheet for the ISL95338 (couldn't find one for ISL9538,...
      05-03-2024, 03:25 AM
    • mkdj
      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
      by mkdj
      Dear all,
      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
      Both N-Channel Mosfets: nothing odd
      P-Channel MOSFET number 1:
      source - drain : 117 kOhm
      source - gate: 96 Ohm
      gate - drain: 117 kOhm
      P-Channel MOSFET...
      08-20-2025, 06:08 AM
