Sony KDL-55W800A green / amber status flash
  • Michegianni
    • Jan 2017
    Hi guys,
    I'm a newbie to all this stuff so any help would be greatly appreciated...
    My initial problem was I had the red light blinking three times, after all checks in the service manual, proceeded to replace the BA2S (main)board as it was the most likely cause, now after powering on the TV, the green and amber status LEDs flash on an oscillating basis...
    I have downloaded the latest firmware from the Sony website, formatted a USB stick to FAT32 and copied to the root folder of the USB. The TV when powering up reads the USB drive and flashes a couple of times but then stops. This has now been on for about an hour, still no progress, just flashing amber, green, amber, green...
    When the TV powers up, the white status LED comes on, the panel LED backlight flashes for 1/2 second and then the green/amber starts flashing.
    Is there another way to "force" update the firmware on the TV? I don't have the original remote, if I get one and do a reset, will this work to enable me to get into the settings menu, or is there anything else I could try first?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Sony KDL-55W800A green / amber status flash
    First we need to see some high resolution, straight shot pictures of all your boards and another one of the backside of the TV to see how all is connected together.
    Did you try unhooking everything but the backlights from the PSU and force the PSU on? Once the PSU is up and running, do the backlights stay on and all voltage rails on the secondary are up and running?
    • joosuas
      • Nov 2017
      • Finland
      Is there any way to force fw update? I'm in same situation as you Michegianni
      • waleed.ibrahimtech
        • Jul 2018
        • Iraq
        Originally posted by Michegianni
        Hi guys,
        Thereis orther way add me in viber i will give you the steps 009647703333755
        • shahnld
          Sony kdl 65xg9505 green amber blinking
          by shahnld
          Good Day.
          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
          01-03-2024, 03:05 PM
        • Ihandyrepair
          4 red flash led 65X950G boot Sony and android logo but then black
          by Ihandyrepair
          HI guys
          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
          here is the issue
          I have Sony and android logo. but then 4 led red flash lights front of the tv
          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
          but then I get black screen and 4 red flash light at the front LED
          but I get 3 led flash on the LED driver board.
          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
          so I tried...
          07-11-2024, 01:45 AM
        • mrsith
          Sony KDL-55W755C - Dead
          by mrsith
          Hello again lifesavers.
          I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
          I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
          11-28-2022, 12:42 PM
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
