Vizio VO370M-C Vertical Lines
  • KoenigsTiger
    • Jan 2017
    • 25
    Re: Vizio VO370M-C Vertical Lines
    Ok, I'm finally seeing the test points.
    What dcvolts should they be? all the same?
    • KoenigsTiger
      • Jan 2017
      • 25
      weird, I was measuring VDD DCV and the TV is shutting down by it self now....
      • KoenigsTiger
        • Jan 2017
        • 25
        Well, I know you didn't ask for VDD, but I wanted to measure it for sugar & giggles. Few seconds after testing VDD the TV turned off by it self... I was testing it screen down on the floor... It turned off about 3 more times, ON for only 35sec at a time. Then I stood the TV upright and now its working fine...
        I tested the VDD again, but the TV is not shutting down anymore.
        VDD=16.17
        VCOM=7.48
        VGH=initially 12.67 went up to 13.30 and stayed there (are these values depended on whats playing on the screen?)
        VGL=7.46
        VCC=3.297
        VCC1.8=1.800
        Thank you budm
        • KoenigsTiger
          • Jan 2017
          • 25
          Well, now its shutting down again every 36sec. while laying flat on its face... I know small home heaters have a shut off built in but do TVs have something like that also?
          • KoenigsTiger
            • Jan 2017
            • 25
            I retested DCV for fun:
            VDD=16.13
            VCOM=7.48
            VGH=13.05
            VGL=7.45
            VCC=3.299
            VCC1.8=1.799
            TV is still shutting down by it self every 37sec...
            • KoenigsTiger
              • Jan 2017
              • 25
              If the T-Con board is bad, does the number on the sticker on back of T-Con board must match the replacement?
                VGL should show as negative, so is it 7.45VDC or -7.45VDC?
                • KoenigsTiger
                  • Jan 2017
                  • 25
                  I just retested the VGL. Its, -7.44VDC
                  Thank you for helping budm
                  • KoenigsTiger
                    • Jan 2017
                    • 25
                    I know it very well may not be the T-Con board, but if I want to buy one.
                    On shopjimmy.com the one has the same part number as mine but has less components on the board, will that board still work in my TV?
                    My partial p/n on back is 1579A, so the part I am looking for is 6871L-1579A?
                    Thank you,
                    Gene
                      I would contact SHOPJIMMY.
                      • KoenigsTiger
                        • Jan 2017
                        • 25
                        I received a different used t-con board, and the TV works
                        Thank you very much for all your help!!!
                        • Stanley1843
                          by Stanley1843
                          06-29-2024, 11:54 AM
                        • brad2157
                          Vizio E70-E3 Two white vertical lines
                          by brad2157
                          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                          Replacement main board - Boots up fine, but starting...
                          12-13-2021, 05:11 PM
                        • pni
                          LG 49uf695v vertical coloured lines
                          by pni
                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                          11-14-2025, 03:15 AM
                        • howardc64
                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                          by howardc64
                          Failure Symptom
                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                          Where is the short?
                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                          05-27-2025, 02:56 PM
                        • Daren87
                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                          by Daren87
                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                          08-13-2023, 03:25 PM
