Toshiba 23l1350u standby voltage present, won't power up
    Re: Toshiba 23l1350u standby voltage present, won't power up
    Blank PCB # VTV-L32615 REV 1A
    PCBA # on the Barcode sticker:
    Toshiba 23L1350U Main Board 431C5Y51L42
    http://www.tvparts.ca/tvdetail.php?id=1429
    You should also verify if the T-CON is getting 12VDC (or 5VDC) at both ends of the SMD fuse on the T-CON board.
    The backlights circuit can also be forced on by disconnecting the BL-ON and the DIM control wires going to the main board first and then used 1K resistor between 5V and the BL-ON, 1K between 5V and the DIM control line, if other functions of the main board are OK you should then see images on the screen.
    • AcGeorgiegirl
      • Jun 2013
      • 203
      no power on as testing resistance then test between pin 12 and pin 1 and yes ohms mode
      Thanks. I tested using negative probe to gnd pin and positive to the BLon pin, with no power plugged in. Got 4.78 on the 20k ohms setting.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        So there's no problem with the BLON on the power supply, ie short or low resistance.
        Budm has given the method to test the backlights so it will be interesting to see the results.
        • CapLeaker
          Leaking Member
          • 8351
          you got 4.78 what? Ohms, kOhms, etc? 4.78 kOhms isn't a short.
          • AcGeorgiegirl
            • Jun 2013
            • 203
            I've looked everywhere I know of for the schematics of this TV, but no luck. I am hoping to find someone with a service manual that includes schematics, and buy it, if so.
            I will be getting around to starting the backlight and tcon testing, as you've instructed, soon. I'll no doubt have questions
            • AcGeorgiegirl
              • Jun 2013
              • 203
              thanks, Mr. Barton! (and Budm)....I'll be getting started soon with testing. It's time I learned a bit more in-depth, so I'm determined to dive in. Much thanks for bearing with my "process" of learning.
              • Dmetro
                • Feb 2018
                I have a 23l1350U issue as well which is not the same but in a similar area, so thought I would try to revive this thread. If this goes against the wishes of the community then let me know and I'll start another 23l1350 thread.
                My issue is the tv will power up to set up mode when first plugged in, operate normally, but when powered off by either the remote or on board power switch, it will not come on again with either remote or power switch.
                The power cord has to be pulled and left out for a minute or so and when plugged in again, it will power up to setup mode again. I've checked the readings on the cable leaving the power board going to control board
                and the only change in measurements is the ACD (AC Detect ?) has 3.2V when first plugged in and working, whereas it has 0 V when the power is shut off with remote or power switch and ac cord still in.
                Without any schematic or service manual (and none I could find) , I am guessing the power board is not enabling the logic on control board to function without ACD turned on.
                Any one have any more service info or experience with this ?
                  • 12328
                  • U.S.
                  #28
                  Probably mainboard issue, can try a firmware update, might not solve tho.
                  • Dmetro
                    • Feb 2018
                    Badcaps Veteran nomoresonys is bang on. After first Firmware flash, both the "power on button" and "remote power on" worked, but it still started in the initial setup mode.
                    I then flashed it a second time with same firmware (went much quicker) and both power on/off methods continued working and it started in the normal operating mode with
                    last channel watched. I have not reassembled so will see if it behaves itself for awhile while apart and then try assembly. Many thanks to nomoresonys !!
                      • 12328
                      • U.S.
                      #30
                      Glad to hear it's working, thanks for reporting back.
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • x_orange90_x
                        Samsung UN55KU6300F no standby voltage
                        by x_orange90_x
                        I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                        Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                        05-21-2025, 09:59 PM
                      • brock-s
                        Asus GL503GE 3.3 standby voltage low
                        by brock-s
                        An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                        Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                        Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                        07-13-2023, 03:43 PM
                        Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                        This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                        09-06-2024, 05:30 AM
                      • Stephen
                        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                        by Stephen
                        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                        02-06-2025, 12:03 PM
