Acoustics Solutions Lcd42761f1080p
  • Robuk
    • Jan 2017
    • 26
    • uk
    Long story short.
    15th December Tv went off stuck on standby flashing blue light.Tv would not start up. Took back off found 2 bad caps and replaced. Same problem flashing blue light wont come out of standby.
    Bought 2 Boards off Ebay, Both DOA, one sent back, other board still to send back. Bought new caps replaced all ones in pic, psu marked with black marker pen.
    Tv now comes on and stays on but no picture or sound. Does not recognise any inputs from HDMI, scart etc. Does show all inputs on screen to choose them.
    Tv has a blue screen, i can get into all menues.
    On entering 4725 and engineers diagnostics everything is ok apart from last check which reads DTV NOK.
    My guess is a problem still with the psu voltages .
    I have watched many youtube videos and there is a very informative video of my exact tv with a link which lead me here. however here is my problem. I have downloaded many scematics for the voltages and there all different. so many Vestel boards.
    Could someone please give me the voltages for the pinouts and testing procedue on the 28 pins that go from psu to main board.I have read here that some have to be tested in standby and then tested again when tv switched on ?.I guess the pins from 2 to 28 are standby and pins 1 to 27 are the voltages to main board when tv is switched on ?.
    I used to tinker many years ago with broken apliances, Have capacitor tester, multi meter and soldering equipment.
    This is a last ditched effort to fix my tv.
    I just got it back from a Tv engineer free estimate , quoted £130 to fix Tv but wont inform me where the problem is. I can use the other board to test and switch out parts it need be if its psu problem.
    Christmas has left me skint, No Tv and i am climbing the walls now.
    I am willing to try and fix it following your guidance.
    TY for any help in Advance .. I read the rules and have attached pictures of the boards in the tv to help you out.
    Rob
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Acoustics Solutions Lcd42761f1080p
    I cant even understand anything you've said at all. So the Tv just doesn't show any sources ? But comes on to the blue no signal background ? Psu would be fine in that case. Maybe reinstall the Tv in the first time install menu on the Dtv. Also it always says dtvnok on Vestels and it says that on this as the tuner is built onto the Mb and not external. You have done a good job on the psu recap though. Mainboard will be faulty if anything. But you cant just swap them over on these sets as they are panel matched.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Also that Tv engineer you spoke to is a rip off merchant £130 what a bloody joke RIP OFF !
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        If you check the voltages on PL816 to see if any are missing when the set is powered up with the blue screen would be a good start.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          DB if the psu had a missing voltage set wouldn't run. Thats why Im confused as he says it just wont change source ?
          • Robuk
            • Jan 2017
            • 26
            • uk
            Sorry to confuse you.
            The tv is turning on now via its remote. I push the source button on remote and can see all the inputs on screen to choose from, "see picture source". when i choose the source ,eg hdmi, scart etc it changes to it on screen but i still get a blue screen. It wont switch to my dvd player "scart" or HDMI ecostar set top box.
            When i select tv source "on remote" i get the no signal as its analogue . On pushing the menu button on remote it shows the tuning section to allow me to tune it.
            When i push the DTV source "via the remote" its just a black screen. The menu does not come up on the screen when i push the menu button on the remote. the screen stays black , see pic.
            The last picture is the diagnostics screen.
            I dont think the main board is getting the power it needs to power the DTV tuner ?.
            This is my first attempt at fixing a tv and the jargon has me confused.
            As mentioned earlier the tv just went off and displayed the flashing blue light.
            I found 2 blown 470uf 35v caps, replaced them with new ones and still had the same flashing blue light. the 2700uf 16v was reading low and i changed that section out and the tv now comes on. the 2 1000uf 35v were reading at 832 and 806 so changed them too.As per the video on youtube the person advised to change all out and i have.
            I have left the tv running for an hour on DTV "black screen" no menu options show when i push the menu button on remote.
            I have taken the voltage readings "TV switched on and tv in DTV selection" Blue screen.
            TY in Advance
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              maybe a firmware issue with the mainboard what is the number from the mainbaord also any numbers from stickers etc also on the back of the lcd panel is there a white sticker that says what lcd panel is used in the set
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Does Pin 13 of PL816 have an 18V supply? Can you check D881, D901
                • Robuk
                  • Jan 2017
                  • 26
                  • uk
                  Main board
                  Green sticker 443076 68680
                  Under green sticker 17mb35-1
                  White sticker
                  10062218 20443075 113 42"
                  26468680 LGELC420VJUD-S GB
                  V60AS
                  Sticker on back of lcd panel
                  LC420WUD
                  (SA)(C1)
                  BAR CODE
                  42089P1752638 731C
                  LG DISPLAY
                  • Robuk
                    • Jan 2017
                    • 26
                    • uk
                    Pin 13 has no voltage at all
                    "Can you check D881, D901"
                    I have found D881, it has D893 printed under it on board. Is this the same diode ? or am i looking for seperate D901 ?.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      if you do need a mainboard there is only one on ebay that should be fine in your set maybe worth offering a cheaper offer nothing to loose i guess
                      http://www.ebay.co.uk/itm/17MB35-1-1...AAAOSwkNZUcNby
                        • 31196
                        what type of caps did you fit?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          I have found D881, it has D893 printed under it on board. Is this the same diode ? or am i looking for separate D901 ?.
                          I don't know how closely your power supply matches the schematic but I attached a section of interest. Is there a voltage at +18_24VA
                          • Robuk
                            • Jan 2017
                            • 26
                            • uk
                            D881 taken off the board
                            Reading 1. one way and .445 the other.
                            Vinceroger69
                            I have that board added to my watch list. Rather than buy it i need to know whether the psu is at fault or the main board.
                            I have bought 2 seperate boards and a full set off caps from Ebay since the 16th december.
                            The Boards were DOA . I was assured that i could change out the 17pw26-3 board for a 17pw26-4 , this is the board i still have here and needs sent back to Ireland, more cost to me. The set of capacitors bought from Ebay did not arrive and i had to buy the caps from the same guy at £2 each who gave me the estimate.
                            This is a pretty frustrating time for me because money is very tight and its my last ditched efford with all the advice here to try and get the tv working again.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              what is board in picture 3?
                              next time you need capacitors etc up cpc i use mostly panasonic fm/fr/fc series for most of my repairs
                              http://cpc.farnell.com/
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                It seems I have confused myself and misread the power supply type as 17PW82-3 which is incorrect. Ignore my previous posts.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  it is a 17PW826-3 in picture 2? unless been changed.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Just checked it again and in post #1, pic 2 it's 17PW26-3 ????
                                    Spares2Repair show the power supply as being 17PW82-3 for the Acoustic LCD42761F1080P!!!
                                    https://spares2repair.co.uk/acoustic...VRAGwodn_oO1Q&
                                    RoBok
                                    Was the original power supply board a 17pw26-3
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      i got mixed up too dont worry i skim read threads at times.
                                      heres a shematic but as reece has said there not always rite due to changes on the board etc
                                      • Robuk
                                        • Jan 2017
                                        • 26
                                        • uk
                                        The power supply is a 17PW26-3
                                        I went to that site too Dick and it confused me.
                                        Spares2Repair show the power supply as being 17PW82-3 for the Acoustic LCD42761F1080P!!! Yes exactly right .
                                        Thats why i asked originally for the true voltages on this tv model and psu because everyone ive searched for and downloaded are all different on the voltages.
                                        I am confused .com
                                        • Thierry Wolffenbuttel
                                          Ps5 with bad standby voltages
                                          by Thierry Wolffenbuttel
                                          I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                                          04-08-2024, 08:04 AM
                                        • Crystaleyes
                                          iMac A1224 PSU, 614-0421 - no standby voltages
                                          by Crystaleyes
                                          Hi chaps.
                                          Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                          I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                          Anyway, this PSU in question had already had someone having a pop at soldering.
                                          The current problem is (at the very least) in the primary side.
                                          Fuse is ok
                                          MOV is ok
                                          NTC is ok
                                          Bridge rectifier is ok (~380vDC)
                                          Fat filter cap is ok
                                          10-11-2021, 05:07 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • zwerw3
                                          la-g07jp no standby voltages
                                          by zwerw3
                                          Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
                                          05-06-2024, 01:01 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
