Acoustics Solutions Lcd42761f1080p
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Acoustics Solutions Lcd42761f1080p
    Originally posted by Robuk
    The power supply is a 17PW26-3
    so this is the original board you have re capped?
    • Robuk
      • Jan 2017
      • 26
      • uk
      Yes this is the board i recapped as pictured in my first post ..
      What pictures you see in my first post is whats in the tv now as it was bought from new.
      Again what confused me, i was informed that you can switch the 17pw26-3 with a 17pw26-4 or 17pw26-2. You just have to make sure the replacement is from a 37 to 42" Tv as they have a 450v Pollycap and larger transformers.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It may be worth trying a replacement EEPROM. Speak with Ohms Supply and see if it is a suitable replacement for your mainboard.
        http://www.ohmsupplies.co.uk/ACOUSTI...1F1080P-EEPROM
        • Robuk
          • Jan 2017
          • 26
          • uk
          Hi Dick . Ty for that link ...
          It looks like a spider lol.
          So if the voltages are correct and the psu is working that means the main boards at fault ?. The psu failing has corrupted the EEPROM ?.
          Ive had a few motherboards where the bios chips needed replacing and thats as far as my knowledge goes.
          As mentioned i do get items brought to me to fix and mostly i am succesfull.
          Recently ive had to change out a bad vid cable on a hp DV7. and change out cfl tubes in a monitor. Tracing faults on electrical boards etc leaves me bewildered .
          Is there a fuse or something similar on the main board i can check ?.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Pw82 42" is compatible with any other PW26 for 42" model so thats not the fault.
            • Robuk
              • Jan 2017
              • 26
              • uk
              #26
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                Useful to know. Cheers
                • Diah
                  • Feb 2013
                  • 6438
                  hold on... your first post you did entering 4725 engineers diagnostics menu... go back there again and look after hotel modes.. you may switch it on LOL
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Spot on Diah nice one I forgot about that
                    • petehall347
                      • Jan 2015
                      • 4438
                      #30
                      would it power on with a corrupt eeprom ? i just did one that didn't even power up .
                      as diah said check the settings . tv engineer may have been playing around a bit
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Yeah, Im sure you know that the 26-32" Versions have a smaller transformer while they will work with the mainboard they wont be able to power the backlight of a 42" might be able to get away with a 37" but 42" it will abort due to over current at start. But the 42" version of this supply will power all 26-42" versions of these Tv's with the same mainboard connector
                        • Robuk
                          • Jan 2017
                          • 26
                          • uk
                          #32
                          Had alook at service settings . see Pictures.
                          The hotel option is set as yes and grayed out "cant be switched to no"
                          I went into the programming section and uploaded pic of settings in there too.
                          I have not adjusted any settings .
                          The problem with this tv has me tearing my hair out.
                          I get no sound or video inputs eg hdmi, scart etc. yet in the menue screens i can adjust the picture/ volumes/ pip/pap settings, everything is still user adjustable. There is no DTV at all. I cant remember the dtv because ive always used a HDMI freeview set top box with recording functions built into it.I forgot that this TV even had a freeview tuner built into it.
                          When this tv went off , I had my laptop connected to it through HDMI , i was reinstalling my laptop with an image created earlier. I left the room to come to my gamer pc , when i went back the tv has the problem mentioned here.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #33
                            this may help
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Factory reset the Tv ?
                              • petehall347
                                • Jan 2015
                                • 4438
                                #35
                                try unlocking the feature with pin code .. might be 0000 if it hasn't been changed
                                • Diah
                                  • Feb 2013
                                  • 6438
                                  don't panic its easy to rid off hotel mode
                                  those code for your info
                                  Various VESTEL SERVICE MODES to try:
                                  STANDARD/DEFAULT: MENU, 4,7,2,5;
                                  CALIB MENU: MENU, 4,7,2,6
                                  HOTEL MENU: MENU, 1,3,2,5
                                  VESTEL - 17MB25-35 CHASSIS
                                  HOTEL MODE: MENU, 7,9,3,5
                                  if in digital, press MENU, then select TV setup, and input above.
                                  • Robuk
                                    • Jan 2017
                                    • 26
                                    • uk
                                    #37
                                    Vince
                                    I followed that guide and the hotel mode is set to off. In options on TV Hotel options is set to yes and grayed out.
                                    Reece
                                    in service settings,
                                    6. Preset shows
                                    1 USER ADJ
                                    2 ADC ADJ
                                    3 SERVICE ADJ
                                    4 ALL ADJ
                                    5 INIT FACTORY CHANNELS
                                    All came up with Please wait and then Done.
                                    Pete
                                    That instruction went straight over my head.
                                    • Robuk
                                      • Jan 2017
                                      • 26
                                      • uk
                                      #38
                                      Hotel screen
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #39
                                        that looks like its turned off ok now have you tried re tuning the tv channels
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #40
                                          just re read your thread you say
                                          i wonder if the laptop re booted and somehow sent a voltage through the hdmi lead? that has now blown a part or corrupted the eeprom?
                                          • Thierry Wolffenbuttel
                                            Ps5 with bad standby voltages
                                            by Thierry Wolffenbuttel
                                            I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                                            04-08-2024, 08:04 AM
                                          • Crystaleyes
                                            iMac A1224 PSU, 614-0421 - no standby voltages
                                            by Crystaleyes
                                            Hi chaps.
                                            Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                            I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                            Anyway, this PSU in question had already had someone having a pop at soldering.
                                            The current problem is (at the very least) in the primary side.
                                            Fuse is ok
                                            MOV is ok
                                            NTC is ok
                                            Bridge rectifier is ok (~380vDC)
                                            Fat filter cap is ok
                                            10-11-2021, 05:07 PM
                                          • Capacitorial
                                            Powersupply has all the voltages - Monitor still no power
                                            by Capacitorial
                                            Hello guys,
                                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                            The weird thing is, that the Power LED is powered over the TCON board.
                                            On The TCON...
                                            12-28-2024, 02:12 PM
                                          • zwerw3
                                            la-g07jp no standby voltages
                                            by zwerw3
                                            Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
                                            05-06-2024, 01:01 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
