Acoustics Solutions Lcd42761f1080p
  • Diah
    • Feb 2013
    • 6438
    Re: Acoustics Solutions Lcd42761f1080p
    that looks like its turned off ok now have you tried re tuning the tv channels
    No Dear friend,, he had Hotel mode active from his photo
    in hotel mode he had hotel mode Yes ( mean active )
    IR smart no ( this need to turn yes then he can change hotel mode to No.
    this setting if the Tv installed in Hotel, customer will be not able to switch the Tv as normal mode via RC
    this is for you the service manual, read after page 59
    • Robuk
      • Jan 2017
      • 26
      • uk
      #42
      Vince
      when the tv is in tv mode i can get the menu screen up and it is actually scanning the channels but analogue signal was turned off.
      I turned the blue background off and i get the snowy screen.
      The DTV does not seem to be working. i push the Dtv then the menue button and nothing happens . No menue or tuning screen like i have in the tv analogue tuning section.
      I have also noticed now that when the tv is in standby mode the led is flashing where it was a solid blue light befor. Ive just read the instruction manual and it Reads
      when the tv is switched to standby mode, standby LED can blink to indicate that features such as standby search, over air download or timer is active .
      When i went back into the other room after the image install i had both laptop and tv screens visable. It was all working good.
      The next day my son was watching the tv and left it on standby and went to bed. i went to watch an hour of Tv befor bed and it would not come out of standby.
      My Son told me last night that the TV was taking longer and longer to come on. He leaves the tv on standby when he goes to bed and i watch an hour of it befor bedtime and turn the tv fully off when i go to bed. I cant remember the last time i actually started the tv up from cold.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        Thanks will have a read of it im still learning tv repair myself so any pdfs like this are good.
        • Robuk
          • Jan 2017
          • 26
          • uk
          #44
          Diah
          Am i missing something here ?. confused
          HOTEL MODE: MENU, 7,9,3,5
          In my picture "hotel" hotel setting is off meaning its giving the user full access ?.
          Pushing the 4725 in diagnostic settings its set to yes and greyed out.
          7935 overides 4725 ?. which means hotel settings is off and user has full access ?.
          if 7935 setting is on then user is limited ?.
          Sorry for my dumb reply but this is all a new learning curve for me.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #45
            Originally posted by Robuk
            Diah
            This confused me too even reading my pdf i posted then diah pdf im still confused
            • Diah
              • Feb 2013
              • 6438
              there are 2 option , main service mode , which it show under hotel mode Yes, IR smartloader NO, ( this main function )
              hotel menu ( menu ) are the setting for Hotel mode when it switched to on.
              it show on your photo OFF, but last state was ON. and you said you had never changed any value, however it show now YES at the main service mode.
              you installed your PC while it was pluged to the TV via HDMI or any other source.. this TV had option it can be programmed from out source via terminal. so its likely the PC setup missed up with TV eeprom . this why it had switched hotel mode at main menu.
              go to hotel menu ( menu ) and try if you can switched it from off to on. so it matched the setting at first main service menu.. if this succeed then can be changed later when hotel mode switched off.
              iR smartloader turn it on.. i think it will ask password try 0000 in order to responce to RC comand to change hotel mode option
              all this not help, then there will be only to programm it via terminal, and its quite difficult , so better change main board.
              • Diah
                • Feb 2013
                • 6438
                also go to hotl mode menu ( menu ) and plug empty usb format FAT32 and choice copy to USB, the file of hotel mode you have compress then to zip and upload them over here to read your TV setting and if any change can be done to write them back to TV
                • Robuk
                  • Jan 2017
                  • 26
                  • uk
                  #48
                  Hi Diah
                  My TV does not have usb connection.
                  i will go and follow your instructions now .
                  • Robuk
                    • Jan 2017
                    • 26
                    • uk
                    #49
                    No luck on the instructions
                    it will not allow me to switch the iR smartloader to on. its always grayed out.
                    • petehall347
                      • Jan 2015
                      • 4438
                      #50
                      is there a security setting in the menus ?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #51
                        im also suprised its not asking for a code to unlock the menu in both pdfs it shows a password menu
                        whats peoples thoughts on replacing the eeprom if theres one available? are the hotel mode settings stored in it?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          Post #23 Ohms Supplies, but for BOARD TYPE: 17MB26-3 which is why I suggested contacting them to see if it would be suitable for his board.
                          • Robuk
                            • Jan 2017
                            • 26
                            • uk
                            #53
                            Pete
                            I cant find any security settings in menu.
                            Vince , Dick
                            Its not asking for any code which makes me believe im not following diahs instructions properly.
                            In the 4725 menu the hotel mode always read YES and iR bootloader no, both always grayed out.
                            The 7935 setting allows me to change them , also reads to power off tv to write settings to EEPROM which i did.
                            I followed that link you sent to me in post 33 vince. Then posted the hotel Picture in post 38. It does not ask for any input code ?.
                            I have contacted Ohms Supplies and waiting on their reply.
                            I would like to thank you all for your advice and input to my TV problem. without your help this TV would have been taken to the tip for recycling.
                            If after all this i cannot get it working then, I have its original box , manual, "brand new" original tv remote and spare remote.
                            Im not going to give up on it just yet, but i am close to giving up. I will box the tv up and get it sent out to who ever wants it for parts. The tv itself is imaculate.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #54
                              did you do a proper power off not into stanby?
                              • Robuk
                                • Jan 2017
                                • 26
                                • uk
                                #55
                                I think i powered it off on panel button. not remote. It was never powered off from wall socket?.
                                it was powered off while in 7935 hotel settings after changes were made.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #56
                                  not sure if it matters? but if in standby it may not work? try unplugging it nothing too loose.
                                  • Robuk
                                    • Jan 2017
                                    • 26
                                    • uk
                                    #57
                                    Ile go and follow those instructions again
                                    This time in 7935 menu ile make the changes and just take plug from its socket.
                                    • Diah
                                      • Feb 2013
                                      • 6438
                                      this should be, it written at the pdf i upload to you,, any change of service menu will take effect only after change plug out from wall socket to save the change on eeprom
                                      • Robuk
                                        • Jan 2017
                                        • 26
                                        • uk
                                        #59
                                        Still no luck on setting IR Bootloader to on.
                                        I think it has to be done in DTV mode to initiate those settings. Thats why i have no code to unlock the menus. Unfortunately i cannot get the menu up when i select DTV mode, it displays a black screen and nothing else.
                                        Still waiting on a reply back from Ohms supplies.
                                        • Diah
                                          • Feb 2013
                                          • 6438
                                          i am confused now.. how you can change them and you said no luck..
                                          • Thierry Wolffenbuttel
                                            Ps5 with bad standby voltages
                                            by Thierry Wolffenbuttel
                                            I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                                            04-08-2024, 08:04 AM
                                          • Crystaleyes
                                            iMac A1224 PSU, 614-0421 - no standby voltages
                                            by Crystaleyes
                                            Hi chaps.
                                            Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                            I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                            Anyway, this PSU in question had already had someone having a pop at soldering.
                                            The current problem is (at the very least) in the primary side.
                                            Fuse is ok
                                            MOV is ok
                                            NTC is ok
                                            Bridge rectifier is ok (~380vDC)
                                            Fat filter cap is ok
                                            10-11-2021, 05:07 PM
                                          • Capacitorial
                                            Powersupply has all the voltages - Monitor still no power
                                            by Capacitorial
                                            Hello guys,
                                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                            The weird thing is, that the Power LED is powered over the TCON board.
                                            On The TCON...
                                            12-28-2024, 02:12 PM
                                          • zwerw3
                                            la-g07jp no standby voltages
                                            by zwerw3
                                            Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
                                            05-06-2024, 01:01 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
