Acoustics Solutions Lcd42761f1080p
  • Diah
    • Feb 2013
    • 6438
    Re: Acoustics Solutions Lcd42761f1080p
    post please photos on the service menu No 8 programming all what you have inside
    • Robuk
      • Jan 2017
      • 26
      • uk
      #62
      Diah , Ty for your time.
      1st picture = Hotel tv now in 7935 menu
      2nd picture = Hotel now in 4725 menu Ir smartloader still grayed out
      3rd picture = Programming in 4725 menu
      4th picture = contents inside Programming
      • Diah
        • Feb 2013
        • 6438
        okay, first programming are correct
        second when you turn on hotel with 7935 pic1 did you tried with pic2 use 4725 to switch hotl to NO , or its grayed too ?
        back to pic1 when you use 7935 after change hotel to ON, tr change the source from auto to other source you used to use the TV. HDMI or other source, it should work too.
        also after you change as pic1 if you used to put signal via scart to the tv as DTV the menu will displayed to you so you can go with to switch hotel from yes to no
        • Thierry Wolffenbuttel
          Ps5 with bad standby voltages
          by Thierry Wolffenbuttel
          I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
          04-08-2024, 08:04 AM
        • Crystaleyes
          iMac A1224 PSU, 614-0421 - no standby voltages
          by Crystaleyes
          Hi chaps.
          Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
          I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
          Anyway, this PSU in question had already had someone having a pop at soldering.
          The current problem is (at the very least) in the primary side.
          Fuse is ok
          MOV is ok
          NTC is ok
          Bridge rectifier is ok (~380vDC)
          Fat filter cap is ok
          10-11-2021, 05:07 PM
        • Capacitorial
          Powersupply has all the voltages - Monitor still no power
          by Capacitorial
          Hello guys,
          I have a Philips 240B7QPJEB. The monitor seems completely dead.
          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
          The weird thing is, that the Power LED is powered over the TCON board.
          On The TCON...
          12-28-2024, 02:12 PM
        • zwerw3
          la-g07jp no standby voltages
          by zwerw3
          Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
          05-06-2024, 01:01 AM
        • psssst
          Yamaha TSX 120 Standby Problem
          by psssst
          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
          03-01-2024, 07:25 AM
