LG 50PJ350 turns off by itself! This is how my wife fixed the right way.
  • capwizard
    • Jun 2016
    • 1991
    LG 50PJ350 turns off by itself! about 20min -30min, sometimes happen right away!
    After Ive read all this, I am more confused!!!
    https://www.badcaps.net/forum/showthread.php?t=53662
    LG Power Supply EAY60968701 Repair [Fix Clicking noise] 50PJ340 50PJ350 50PJ550 50PJ650 Z50PJ240
    https://www.youtube.com/watch?v=RMEyFfIbpAQ
    EAY60968801 EAY60968701 EAX61392501 schematic repair
    https://www.youtube.com/watch?v=NmifFBrB8BM
    LG 50PJ350-UB Power board problem
    https://www.badcaps.net/forum/showthread.php?t=24646
    LG 50PJ350 Power Supply Repair
    https://www.badcaps.net/forum/showthread.php?t=22713
    http://www.shopjimmy.com/lg-eay60968...repair-kit.htm
    http://www.ebay.co.uk/itm/EAY6096880...3D271509736520
    I told her, maybe is the IC301 or the diode? I tested all day every-time when TV shutdown i am doing something else....
    First: She used hair dry heat the suspected place with.
    Second: She use AirWick Air Freshener Spray cool down the area, TV shutdown right away...........YES, it was the 3BR1565.
    PS: Recommend at least use DUSTOFF, I hate air freshener's smell.....
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: LG 50PJ350 turns off by itself! This is how my wife fixed the right way.
    Using the evaporation of rubbing alcohol to cool a component can work, too.
    PeteS in CA
    • capwizard
      • Jun 2016
      • 1991
      Do you mean perfume or Vodka! ...Yes, rubbing alcohol with A swab is kinda danger if you drop liquid on live tv modules........
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        I have a huge spray can of residue less cleaner I use on radio tuning capacitors. It leaves frost when it evaporates.
        sigpicThe Sky Is Falling
        • capwizard
          • Jun 2016
          • 1991
          Would you be so kind let all the Badcaps Veterans know what kind of cleaner is that?
            • 31286
            most air fresheners etc use butane as the propellant - it's not a good idea spraying onto something hot!!
            • capwizard
              • Jun 2016
              • 1991
              Oh! I forget about the butane C4H10, it is pretty safe, if you use at absolute zero environment.
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                ECG Industrial RX401-16 New 141b alternative non flash cleaner.
                http://www.parts-express.com/ecg-rx4...16-oz--341-506 .
                • capwizard
                  • Jun 2016
                  • 1991
                  that is a expensive contact cleaner! as I can't afford so i use WD40 as A contact cleaner which leave oily residue smell like kerosene and did the jobs.
                  MY TIPS: After change 3BR1565, you do need put some heat sink compound, a white thermal paste, I hate it, white stain mess everywhere. I sub with this( PIC 1,2), original use for car transmission, which i used in CPU processor and Xbox GPU ......for about 20 years still has some left.
                  • dit3
                    HP ProBook 455 G7(DA0X9MMB8F0), fixed bad RAM power rail, laptop works, but now automatically turns on after AC is connected
                    by dit3
                    Hello everybody,
                    I got HP ProBook 455 G7 which originally turned on partially(fans on 100%) and hen off after 8 seconds, with AC diode flashing orange and last flash white. This behaviour stayed for a while, but before I realised that there is power delivery issue and not BIOS problem, laptop started to automatically turn on after 2 seconds when in turned off, kept power cycling. So after I fixed shorted cap and burned ferrite bead, laptop turned on fine and booted to windows.
                    Now, laptop can be turned off and it stays like that... unless you plug adapter again, which triggers...
                    01-06-2024, 04:44 PM
                  • Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                    by Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                    03-15-2024, 09:37 AM
                  • www
                    LG L192WS-BN backlight turns off after 1 second
                    by www
                    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                    03-24-2024, 05:26 PM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • andrhouseolly
                    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                    by andrhouseolly
                    Hi.
                    I kindly ask you to help me solve the problem.
                    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                    The board turns on, there is no image.
                    Read more. When the power supply is connected, the front panel indicators light up briefly.
                    When you press the power button, the button indicator lights up. The board works
                    there is no image, there is no matrix initialization, there is no image on HDMI.
                    When turned on, the fans do not spin, but when they warm up they start spinning.
                    When you turn off the button, the fans spin up to full speed for a short...
                    05-11-2024, 03:14 PM
