LG 50PJ350 turns off by itself
  • C_nuggz
    • Feb 2016
    • 9
    • United states
    I have 50PJ350 that I was lucky enough to get for free as the person was taking out to the side of the road. It had the common power supply fault and I also replaced the ysus, zsus, and both upper and lower buffer boards since I found them for a great price. It has been working great for a few weeks now and just started to turn off by itself then constantly click with the power light also constantly flashing. The only way to stop this is to unplug the tv. If I unplug the tv for a few minutes and plug it back in the tv works fine for awhile then it goes back to turning off and constantly clicking. I'm thinking it might be the 16v 100uf cap and the fet close to the ceramic resitors. I saw that fix on a 50PK350 thread and thought that might be the problem. Does anyone have any idea why it does this?
  • comptek
    • Aug 2013
    • 606
    • uk
    Re: LG 50PJ350 turns off by itself
    check again for dry joints on all boards first
    • candy-men
      • Apr 2016
      • 13
      Measure the 12V line (if available) . I had a similar Problem with a PDP50H20000
      There was a 12V Regulator faulty. It only does 10Volts and decreasing. At 9.5V the Power supply switches itself off. this took 10-20Minutes till it was off.
      I replaced the regulator and all was fine.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Got the part number of the reg and the circuit number ?
        • C_nuggz
          • Feb 2016
          • 9
          • United states
          I just went through and checked found one that looked suspect so I fixed it and same problem tv works but turns of after awhile.
          • C_nuggz
            • Feb 2016
            • 9
            • United states
            Do you know if there is a 12 vilt line on this model I have looked but maybe I just overlooked it?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Have you a part number or what ?
              • C_nuggz
                • Feb 2016
                • 9
                • United states
                You do mean the power supply correct? The ps number is EAY60968701-EAX61397101
                • Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                  by Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                  03-15-2024, 09:37 AM
                • www
                  LG L192WS-BN backlight turns off after 1 second
                  by www
                  I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                  I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                  03-24-2024, 05:26 PM
                • zklgfs
                  Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                  by zklgfs
                  I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                  08-11-2025, 02:14 PM
                • andrhouseolly
                  Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                  by andrhouseolly
                  Hi.
                  I kindly ask you to help me solve the problem.
                  Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                  The board turns on, there is no image.
                  Read more. When the power supply is connected, the front panel indicators light up briefly.
                  When you press the power button, the button indicator lights up. The board works
                  there is no image, there is no matrix initialization, there is no image on HDMI.
                  When turned on, the fans do not spin, but when they warm up they start spinning.
                  When you turn off the button, the fans spin up to full speed for a short...
                  05-11-2024, 03:14 PM
                • Egidio85
                  Samsung UE55F8000SZ Turns on and off immediately
                  by Egidio85
                  good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                  This defect happens continuously, hearing the classic click of the relay every time.
                  Power supply board BN44-00636B
                  disconnecting the mains and lamps from the power board always causes the same problem.
                  Is it normal that without anything connected this power supply turns on and off cyclically?
                  any suggestions on what to check?
                  thanks in advance
                  03-11-2025, 12:45 PM
