LG 50PJ350 Power Supply Repair
  • sluhbmet
    • Nov 2011
    • 4
    Hello All,
    I've got a LG 50PJ350 plasma tv that I got cheap because the power supply would click constantly when plugged in, even with no other boards attached to it. After a few evenings of troubleshooting and component replacement "I think" I have it fixed because all voltages (VS, VA, M5V) are present and stable when plugged into AC only. However, when I connect the y-sustain board the clicking returns. I'm fairly certain that there is a problem with the VS line in the y-sustain board. Before I start troubleshooting it, I want to make sure the VS, VA, and M5V lines of the power supply are operating correctly under an appropriate load. Is there a way to load test each of these output lines from the power supply using resistors? I'm especially interested in what size wattage resistors to use. The power supply has the following ratings listed on it.
    VS: 206V -1.6A
    VA: 60V - 2.0A
    M5V: 5.1V - 3.0A
    Thanks,
    sluhbmet
    Re: LG 50PJ350 Power Supply Repair
    You can try using a 230V lightbulb, rated for 100W or so. That would represent a moderate (ordinary TV picture) plasma panel load. For VA - maybe using a 120V bulb would be OK, two in parallel would draw ~0.83A.
    • sluhbmet
      • Nov 2011
      • 4
      Tom66,
      Thanks for the quick reply. I went ahead and tied two 100 watt bulbs in series and ran them on the VS output for about 30 minutes. Bulbs were bright and the voltage held steady. Now on to the y-sus board.
      Thanks again.
      • waitery
        • Feb 2011
        • 69
        Hi Tom,
        I have this same LG set as well (50PJ350) and I recently put in a new power board after the screen went dark and got no sound. After putting in the new board, I still get no video, no OSD, but now I get static through the speakers, which is different than before. The static sounds like "snow" when you change channels with no input connected to it.
        I have taken the voltages off the top off the rail and they are all solid and stable (VS=207, VA=60, M5V 5.1, etc), plus ALL the fuses on the power board, and all the sustain board show continuity and are not blown. For what it is worth, the main board shows the optical out glowing when the set it on. Lastly, when I try and use the remote to change to a different channel or input and I get nothing.....no flash on the screen, no image, no light at all on the screen. I fear that I have a bad panel, but was hoping that you could help me perform some further troubleshooting before I jump to conclusions. Thank you for your time and consideration in advance.
        • capkid
          • Oct 2010
          • 1339
          Have you checked your Y-Sus (-Vy and VSC) and Z-Sus (Vzb) output voltages? Also, see the attached control board check.
          LG Plasma Mal-Discharge Correction Service
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • CMCM
            Russound CA4 Power Supply Repair
            by CMCM
            Hello Everybody,
            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
            The outputs marked 12v and 20v are all measuring only 1v.
            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
            The capacitors physically look clean (no bludgesor leaks) and...
            07-03-2025, 01:12 PM
