Sharp Aquos LC-32LE244 TV stuck in standby (solid red LED)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. As the title suggests, I've got this LC-32LE244 Aquos TV which doesn't turn on. The LED on the front is red and doesn't do anything AT ALL when I press the buttons or use the remote - it doesn't blink or turn green or anything. I think it's safe to say the main board is dead because the power supply works fine (I did the force-on test by connecting a low value resistor between "on" and 5Vsb and it fired up: all volts were OK, including the PFC which went up to 400v on the main cap as it should). Another thing I tried was heat up the board and then plug it in - no changes. I'm pretty sure it's going in the bin, but I thought I'd ask if anyone had similar issues and what they did to solve it...aside from getting a new board/TV of course
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Sharp Aquos LC-32LE244 TV stuck in standby (solid red LED)
    Forgot the pics duuh
    Wattevah...
    • CapLeaker
      Leaking Member
      • 8177
      So main IC isn't sending PSon. = Bin
      • vinceroger69
        • Mar 2012
        • 6714
        reflow main ic? nothing to loose if already broke. (just re read post 1 you may of allready tried this)
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Haven't done a proper reflow with flux and stuff - just a quick blast over the whole board with the hot air station to see if it changes anything. I'll try it anyway and see if works - doubt it, but just as you said: nothing to lose at this point....really hate it when ICs don't have heatsinks on them. Don't know if it's true or not, but to me that seems like the no.1 reason for IC failure and a sign of dirt-cheap design. Even Vestel boards have a piece of metal over their ICs ! >_>
          Wattevah...
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I agree reflow it, these MSD Ics run very hot, why the fuck would they not heatsink it ahhh !!!
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Reflowing it made no difference AT ALL.....another TV in the scrap heap >_>
              Wattevah...
              • CapLeaker
                Leaking Member
                • 8177
                I knew that this one is gonna get binned!
                • vinceroger69
                  • Mar 2012
                  • 6714
                  as it was a 32in i would of probably sourced another mainboard if cheap enough as it should sell on easy enough with a profit still.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I too had the same feeling from the very start, though somewhere deep inside, hope never dies with electronics
                    Wattevah...
                    • scubacamper
                      Sharp Aquos LC-70C6400U Half Screen Dark
                      by scubacamper
                      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                      05-03-2025, 12:19 PM
                    • lepak06
                      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                      by lepak06
                      Hello
                      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                      01-12-2023, 01:43 AM
                    • sefoster
                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                      by sefoster
                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                      11-20-2022, 09:29 AM
                    • jonah1024
                      Sharp Aquos LC-40UG7252E LCD TV burn in?
                      by jonah1024
                      Hello!
                      I'm a few days old into this TV screens repair universe so please bear with me.
                      Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                      - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                      - I did a factory reset as well...
                      07-16-2024, 04:23 AM
                    • toty79
                      Hisense LTDN50K220WSEU stuck in standby
                      by toty79
                      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                      As per Hisense tv title LTDN50K220WSEU stuck in standby
                      PSU rsag.820.5687 HLL 4855WF
                      Main rsag 7.820.5842
                      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                      05-01-2022, 04:39 PM
