Sanyo dp42d24 will not turn on
  • irad
    • Aug 2010
    • 27
    I have a Sanyo dp42d24 that when I press the power button nothing happens. I checked for power at each of the voltage regulators(4) and got all the correct outputs (1.15,1.8,3.3 and 5v). I also got 12v on audio and 40v on the two led outputs from the board. I checked the power leg of the bios chip and got 3.3 volts. The connector pin on the board where the power button connects goes from 5v to 0 when depressed. The led light never goes on. Can someone please provide me with the firmware? I would also like any advice on what to try next.
    Thanks you, Ira
    PS. The tv has a single board, plus tcon.
  • CapLeaker
    Leaking Member
    • 8127
    Re: Sanyo dp42d24 will not turn on
    IMHO either replace that main board or junk the TV. It is one of these boards where the main IC does everything. So it probably go a little tickle through one of the HDMI ports, frying the main IC.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      +1 normally spi flash Ic firmware corrupts causing these to be stuck in standby. But its easier to replace the board than finding the firmware.
      • irad
        • Aug 2010
        • 27
        I have seen the bios chip sold online. Is there a way to tell if it is the bios chip or the main IC?
        • CapLeaker
          Leaking Member
          • 8127
          That depends on the history of the tv
          • irad
            • Aug 2010
            • 27
            Unknown, I found the tv in the garbage.
            • CapLeaker
              Leaking Member
              • 8127
              then it depends on how much time, headache and $$$ you want to spend to fix it or not, because of no history.
              All you can try here is to freeze the eeprom (can of air upside down) I have a 75% success rate identifying a bad eeprom that way.
              If you read the eeprom description @ SJ, it sez that it will help, IF the LED doesn't change color. You can try to call SJ and ask if the STBY LED supposed to be light up or not when the TV is off. Your's isn't on at all. For me, I'd be changing that board. Who knows what happened to the TV.
              • irad
                • Aug 2010
                • 27
                Thanks, I get freeze spray and try it.
                • irad
                  • Aug 2010
                  • 27
                  Freeze spray did not work. I tried it on the eeprom chip. Then on the main processor msd3393.
                  • Jsikora
                    • Apr 2016
                    • 64
                    Did you get anywhere on this, I have the same one with identical problem and voltages you have.
                    • irad
                      • Aug 2010
                      • 27
                      Not yet. i plugged a usb drive into the tv. I then plugged in the power cord, the usb drive blinked once. So maybe the tv looked for firmware, maybe it was just the usb port powering the drive for a split second.
                      • H34TO
                        ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                        by H34TO
                        Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                        06-17-2025, 07:17 AM
                      • brzostos
                        HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                        by brzostos
                        Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                        After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                        Original HP 150W power supply, the diode in the power socket lights...
                        10-01-2024, 01:34 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • rookieme
                        lenovo thinkpad L15 Gen 2 board NM-D271 usb firmware request
                        by rookieme
                        I'm searching for a usb firmware for the notebook of the title.
                        The issue is that it stays at 5V only input from both usb c ports and the controller TPS65994 has been replaced.
                        The firmware should be the U5502 and I upload the dump of it.
                        Lenovo provides firmware updates but I was unable to find the appropriate file inside.
                        s/n: PF33180Q
                        Thank you....
                        04-09-2025, 04:44 AM
