Insignia TV fried my NEW power board. PLEASE HELP.
  • Reepor
    • Dec 2016
    • 8
    Hello everyone!
    I'm new to this forum, and not extremely experienced with circuitry, so please bear with me while I beg for help.
    So I was given a used Insignia TV that had stopped turning on (see attatched picture, Model# NS-48D42NA16). Specifically, when plugged in, the standby light would turn on, then blink red (from what I've gathered, this signifies an error in the powering on process). I took the back off of the TV, and inspected the power board. I checked to see if any capacitors were bulging first, because I've heard that's one of the most common causes of a power board failure, they all looked fine to the naked eye. I did however, find 2 components on the back of the board that appeared to be "fried" (they looked burnt, and one actually had a chunk blown off of it, exposing metal underneath). I later found these to be black square transistors soldered to small heatsinks (I looked up the part# on them. see attatched picture). Some of the small black square components next to them appeared "fried" as well (I think these are small resistors?). I did not think I could successfully replace the transistors, so I simply purchased a new power board (or rather, a used one from a reputable dealer on ebay)
    This is where things went off the rails. $40 and 2 weeks later I had my new power board, which appeared in excellent condition, and installed it. I reassembled the TV, and plugged it in. It immediately came on, defaulted to HDMI 2, and displayed the "no signal" message. Everything worked great... for about 25 seconds. I then leaned the TV ever so slightly against the wall so that I could find the HDMI cable to plug it in, and IMMEDIATELY there was a loud "POP" and the screen went black again.
    I unplugged the TV, plugged it up again, and lo and behold, that same flashing red light. I took the board back out, and wouldn't you know it, the same transistors on the NEW board look fried!
    That was about 4 hours ago, and frankly I'm at a loss. I'm currently waiting to hear back from the board seller about returning the board, but what are the odds that the 2 boards would fail the EXACT same way? But what outside of the power board could cause the failure? There is a plastic guard in place between the power board and the body of the TV, so I wouldn't think it could have shorted out against the TV. I apologize for the long message, but I want to be as descriptive as possible. I'm new to the world of forums, as I've been living under a rock, so please excuse me if I don't have proper forum ediquite. Thank you to anyone who tries to help, I'm in DESPERATE need!
    Last edited by Reepor; 12-10-2016, 08:50 PM. Reason: Edited to include picture of the back of the TV
    Re: Insignia TV fried my NEW power board. PLEASE HELP.
    Can we see the whole back side of the TV showing all the boards?
    • Reepor
      • Dec 2016
      • 8
      Done and done!
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Originally posted by Reepor
        Done and done!
        What was done and done?
        • Reepor
          • Dec 2016
          • 8
          He asked if I could upload a picture of the whole back of the TV, so I edited the post to include one. Sorry, I should have been more clear.
          • justwannasee
            • Oct 2018
            • 6
            Necro BUMP!
            I have this exact same issue. Ordered a replacement, fried in the exact same way the first one did. Where should I shove my multimeter to test?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              That could probably be due to shorted backlight Driver or LEDs pulling way too much current.
              • chrismurphy
                • May 2014
                • 251
                • australia
                Where are the fried components?
                The circled one are not fried ,just black as they should be
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  True.
                  • justwannasee
                    • Oct 2018
                    • 6
                    SMD resistors at the feet of those MOSFETs are fried. how can I check the backlight driver?
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      With the DMM RED probe on the 4 pins of XP901 and the BLACK probe on the chassis as GND measure the 4 individual voltages at start-up and observe if these voltages peak and then settle. You would have to start-up the TV 4 times. once per pin. Report your findings.
                      • justwannasee
                        • Oct 2018
                        • 6
                        can I have a picture or some diagrams? I don't know that the TV will boot at all with either of these power boards.
                        • justwannasee
                          • Oct 2018
                          • 6
                          Found the issue. burnt LED on one of the strips. Thanks for the clue!
                          • justwannasee
                            • Oct 2018
                            • 6
                            Ok, update. Got a 3rd supply and waited forever for the LED replacement. Now the TV boots but I get no backlights at all (even the ones that were working before). When I check XP109 (of which only 2 pins are actually connected) the voltage settles at ~1.3V when the TV is on. I'm assuming this time the power board is bad, is that correct?
                            EDIT:
                            Forgot I needed to probe each pin individually plugged and unplugged, I'll do that when I get home.
                            • justwannasee
                              • Oct 2018
                              • 6
                              The voltages don't change, I get 1.3V across the two points and from the red wire to chassis both plugged and unplugged. I take it this signifies an open circuit?
