Sharp LC-90LE657u Large LCD panel removal tips?
+ More Options
Posts
  • TECHMECH
    • 21
    Does anyone have any general advice for removing a large 90" lcd panel to get at the led strips? One of freakaftr8 posts suggests that he started with the panel face up. Can this be done with the panel evenly supported and facing down and just removing the LED housing while leaving the lcd/diffusers/frame all in place?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp LC-90LE657u Large LCD panel removal tips?
    Jeez that will be a fun job, best get the Led first so you can it out the way as fast as possible meaning less rick of screen damage. My advise have about 4 people to help get it out the way and rest it on something that is easy to pick the Lcd back up after but just be VERY careful. Also you got us any images matey would like to see inside a 90" set ?
    • zomi
      • Nov 2011
      • 506
      pLAstic sheeting under it
      and lifting like thaT
      or something similar
      just 4 people lifting it without some thing to factor in balance will be hard.
      • flocko
        • Nov 2012
        • 1121
        I have done 70" screens using thick brown parcel rapping paper, slide it under the LCD from the non tab end,then with help lift using the paper to form a stretcher under the screen.
        • mmartell
          • Oct 2013
          • 3189
          Yes, panel face down and lift the panel housing off the screen. Cover the screen and diffuser sheets with something (I use fresh garbage bags) until you are ready to reassemble.
          • TECHMECH
            • 21
            Hi, thanks to everyone for the good ideas. I did not think of sliding a thin sheet of plastic or paper underneath to form a stretcher.
            • TECHMECH
              • 21
              Hi, thanks for the suggestion. On the face down method, does the bezel remain in place? Can you provide any more detail on the face down method?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Biggest Led job ive done is 55" I managed by my self but I have very slender arms so gues that helps
                • mmartell
                  • Oct 2013
                  • 3189
                  No idea on this tv never seen one but I suspect the bezel is hiding the screws to remove the inner frame. You'll be removing exactly what you would need to remove to do the job face up. And of course you'll need to be careful seating the light box on reassembly. Keep us posted.
                  • TECHMECH
                    • 21
                    Well yesterday I managed to get the LCD panel removed. After disassembling the unit, I determined that the "face down" method would not work as the unit was too heavy to be supported by the black plastic frame which centers/supports the LCD.
                    A suction cup jig was created as in the photo using some cheap HFT suction cups attached to some 1in aluminum slatwall extrusions and 1/2 lumber. The masking tape hooks were just used as a backup in the event one of the suction cups came loose. The screen did not flex as much as I originally thought. The measurements of the panel are 80"x46". Haven't got it back together yet, but it appears the culprit was a cold solder joint on one of the LEDs on the first/top row of LEDs.
                    • TimScrawn
                      MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                      by TimScrawn
                      Hi there,
                      This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                      I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                      06-23-2024, 09:41 AM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • sefoster
                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                      by sefoster
                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                      11-20-2022, 09:29 AM
                    • estabilito
                      Tips geting oxidized when using wick
                      by estabilito
                      Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                      i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                      Temperature: 350-365celsius
                      station: jbc cd-2bqe
                      Wick: edsyn
                      flux: warton hf rework jelly
                      Do you have any tips?...
                      04-12-2025, 11:55 AM
                    • gavenb
                      Sharp LC-80LE661U 80 inch
                      by gavenb
                      Hi folks!
                      I have a LC-80LE661U that had some interesting issues.
                      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                      11-12-2023, 02:05 PM
