Samsung LA26R71BA cannot power up
  • john_doe
    • Apr 2013
    • 192
    • Malaysia
    I have a Samsung LA26R71BA that cannot power up. When I press the power button on the remote, a red light on the TV lights up and then off.
    Where should I start to check?
    Thanks.
    John
    Re: Samsung LA26R71BA cannot power up
    So are you saying you are not getting DCV output at all, not even the standby DCV output?
    Did you check all the fuses?
    I also see bad brown glues that must be removed.
    There are also lots of threads for this BN44-00192A, just search the B.C. forum for them.
    • john_doe
      • Apr 2013
      • 192
      • Malaysia
      The fuses are all checked and ok. There is 5v on the standby pin. All other pins has 0 volt.
      Which are the components I should check on the power board?
      • john_doe
        • Apr 2013
        • 192
        • Malaysia
        The voltages I got from QM801:
        Pin 1 to negative of big cap is 340v
        Pin 2 is 0.5v
        Pin 3 is 0.5v
        And for QM802:
        Pin 1 to negative of big cap is 0.5v
        Pin 2 is 0v
        Pin 3 is 0v
        Does it means QM802 is faulty?
        • john_doe
          • Apr 2013
          • 192
          • Malaysia
          Sorry, wrong pin number.
          It should be this:
          Pin 2 is 340v
          Pin 3 is 0.5v
          And for QM802:
          Pin 1 to negative of big cap is 0v
          Pin 2 is 0.5v
          Pin 3 is 0v
          • john_doe
            • Apr 2013
            • 192
            • Malaysia
            I swap QM801 with QM802. There is still 340vdc at pin2 of QM801. So both IC are ok.
            Before the swap, there is no red standby light. After the swap, the red standby light turns on.
            I attach the schematic.
            Any help?
            • john_doe
              • Apr 2013
              • 192
              • Malaysia
              Anyone can suggest anything?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Do you have 5.2V standby and if you have what voltages do you have on the pins of ICM801
                  So is the PS-ON present? Since you are getting only around 340VDC it is telling me that the PFC Boosted Voltage is not working otherwise you would have about 380~400VDC between the two legs of the main filter cap, so it is either the PS-ON is not present or the PFC is not working.
                  • john_doe
                    • Apr 2013
                    • 192
                    • Malaysia
                    ICM801
                    Voltages at all pins are 0vdc, except:
                    Pin 9 0.048vdc
                    Pin 11 0.046vdc
                    Pin 15 0.046vdc
                    PS ON not present. Only have standby power 5.2vdc.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      If you disconnect the main board and connect PS_ON to 5.2V DC using a 1K resistor, do your other voltages come up ie +12V, +13V, +24V, +5.3V as on connector CNM801
                      • john_doe
                        • Apr 2013
                        • 192
                        • Malaysia
                        With PS_ON connected to standby 5.2vdc, all voltages are still 0vdc.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          With your meter set to dc volts can you check what voltage you have between pin 6 (black probe) & pin 8 (red probe) on ICP801S when 5.2V is connected to ON/OFF with main board still disconnected.
                          • john_doe
                            • Apr 2013
                            • 192
                            • Malaysia
                            I cannot find ICP801S on the power board, although it is on the schematic. I can see ICB801S.
                              https://www.badcaps.net/forum/attach...7&d=1478264760
                              It is 8-pin SMD located at top right of the board as shown in the picture.
                              • john_doe
                                • Apr 2013
                                • 192
                                • Malaysia
                                Thanks budm for the location. I was looking at the wrong side. Stupid me.
                                I blown the fuse FP801S. Got to wait for a few days for the new fuse.
                                Please bear with me.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Using a 1K from 5V standby to Power ON/Off, can you check the dc voltage across resistor RB805 and also RB807 and then with the 1K removed. Test with mainboard disconnected from supply.
                                  • john_doe
                                    • Apr 2013
                                    • 192
                                    • Malaysia
                                    I cannot do any testing because the fuse FP801A keeps blowing. As soon as i switch on the power, the fuse will blow instantly.
                                    This only started when i started to probe ICP801S. Now pin 6 and 7 are shorted. Is this normal ?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      you may need to replace that icp8o1s (remove the ic and test again for shorts on those pins once removed from the pcb) also consider building a dim bulb tester as it will save you blowing more fuses/parts.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        It's probably the IC but check DZP801 to see if that is short circuited which would also put a short across Pin6 & 7
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • hill01
                                          Samsung UE75MU7009TXZG Endless Power Cycle
                                          by hill01
                                          Hi everyone and thanks in advance for any help I might get here
                                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                          Since a few days, the TV won't turn...
                                          11-17-2021, 02:52 PM
