Panasonic TH-42PZ80U
  • taxicap
    • Nov 2016
    • 5
    Howdy gang!
    The symptoms: I'm pretty sure it started as a 7 flashing light error - but now - the tv will stay on for about 15 minutes until powering off and retreating into 8 blinks
    have searched and found SS board is common problem on these units - tv from 2008! Would like to save it if possible
    Have a little experience and wondering if someone would baby step me through a further diagnosis process - have a cheapy volt meter ---
    here are the pics - please help me correctly identify any testing points and the SS board ---
    THANK YOU KINDLY!!
    http://imgur.com/a/3evUx
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Panasonic TH-42PZ80U
    I'm in Columbus Ohio. If needed I have the sc, su and sd board that came out of this model tv. All 3 boards work.
    The tv had a bad panel.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Doubt its the SS more likely the Controller Ic and Ceramic cap fault on the psu IMO.
      • taxicap
        • Nov 2016
        • 5
        thanks for the replies gang
        Any chance you would help me get a correct diagnosis on this ?
        would be interested
        • taxicap
          • Nov 2016
          • 5
          would you be willing to baby step me through this? thank yea
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            I really don't know much. I get help from the others.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Watch this hopefully be of some help, this fault can cause a lot of different errors:
              https://m.youtube.com/watch?v=LjpGKaBt8hg
              • vinceroger69
                • Mar 2012
                • 6714
                This link has a test you can try to see if its the ss board issue
                http://www.justanswer.com/tv-repair/...ght-power.html
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Most of the time the IC is good on both "sub boards".
                  I just solder in a new cap on each. Been working for me so far(4 months).
                  You dont have to mount them the way he does it in the video, do it the easy way, small wires soldered to the boards, soldered to the caps, them glue or zip tie to something that stays cool.
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
                  • AquaMan Ua
                    by AquaMan Ua
                    05-17-2025, 09:40 AM
                  • stecos
                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                    by stecos
                    Hi everyone!
                    For my passion for technology I'm now collecting several...
                    11-28-2022, 11:39 AM
                  • aa10aa10
                    Panasonic Toughbook CF-33 mk1 BIOS repair
                    by aa10aa10
                    Good day,
                    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                    01-21-2025, 06:13 AM
