Emerson LC391EM3 - Constant High Pitch Sound
  • ECU_Techie
    • Jul 2016
    • 45
    Hi all!
    So I have an Emerson 39" tv with a model number of: LC391EM3. The problem is the screen will not come on and once plugged in, there is a constant high pitched whine coming from the power board. The area it is coming from is circled in the attached photo.
    Once you unplug the flex going to the main board from the power board the whining stops. I am leaning towards a bad PSU board that is not putting enough power out for the main board, but then again I thought I would ask for some input on this as well.
    - Jeff
    Re: Emerson LC391EM3 - Constant High Pitch Sound
    You have shorted circuit that drawing too much current from the power supply.
    You need to check ALL the diodes in the power supply, check the resistance between GND and the Voltage output pins of the power supply to see if any one of them shows very low resistance. Do not try to power up the unit otherwise you may cause more damages.
    http://www.shopjimmy.com/magnavox-a2...pply-unit.htm#
    Magnavox / Emerson A21T0MPW-001 Power Supply for 39MF412B/F7 / LC391EM3
    Part Number: A21T0MPW-001
    Board Number(s): BA21T0F0102 1, A21T0MPW, A21T1MPW
    • vinceroger69
      • Mar 2012
      • 6714
      These are the parts included in the repair kit for this fault so maybe check all these parts too
      Part Number: A21N0MPW-001 Repair Kit
      Kit Includes
      Description Quantity Board Location
      Fuse 1 F601
      Resistor 1 R611
      Transistors 3 Q501, 601, 602
      Diodes 8 D601, 602, 603, 604, 607, 608, 609, 653
      Capacitor 1 C605
      • tbsmith
        • Sep 2016
        • 22
        I have the same TV with the same whine when the main board is plugged in to the power supply. Did you ever find your problem? I see people on ebay that sell repair kits, one specifically for the whine and won't turn on. It includes what looks like 3 surface mount caps and is cheap enough to try, but I'm not even sure it is the main board or the power supply.
        • tbsmith
          • Sep 2016
          • 22
          I should mention that I pulled and checked all the parts that vinceroger69 mentioned and they all test fine.
          • neilc6
            • Nov 2015
            • 1550
            Trying to find my old thread. I recall I found a service manual and there was a shorted chip cap on one of the regulator rails on the main board. You should be able to measure a short on the supply voltage input of the main board to ground.
            Add - found it. Philips and Emerson are the same. https://www.badcaps.net/forum/showthread.php?t=76666
            • tbsmith
              • Sep 2016
              • 22
              Thanks neilc6. Unfortunately, my ps and main boards are different from those in that thread, so troubleshooting is tough, especially without a schematic. I did check resistance from the various power supplies to ground with the main board connected and disconnected. I did see low resistance (24 ohms) at the P-ON-12V when the main board was connected. Disconnected it was 200 ohms or higher, changing as the capacitor charged.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                That Emerson TV, looks like shit! Sure not like the Emerson plasma TV that we have here!
                Also, you're describing a squealing sound, like my PowMax LPxxxx series 300W PSU, (back when Leadman didn't look as bad, as that was in the early-2000s) when I was hoping that it would be better than the first Deer PSU that I had! But I think it wasn't really!
                (except no dark brown spots all over the place, unlike the first Deer PSU that I had)
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • ivtec
                  • Dec 2008
                  • 1967
                  Also most likely be a bad inductor or transformer.
                  • tbsmith
                    • Sep 2016
                    • 22
                    I fixed it! I found the service manual/schematic in another post for a different model, but same boards. Without that, it would have ended up in the trash. The problem was on the main board, specifically C3103 (a tiny surface mount capacitor near IC3008) was shorted. I found it by checking the resistances of the various power supplies (or rather their loads) and the P-ON-12V was 10 ohms. Pulled 2 other caps before finding the bad one.
                    I'm reposting the service manual in case anyone else is looking for it.
                    A question for the experts: I don't have a replacement capacitor and it powers up fine without it. The question is, is it necessary for long term reliability? It is 4.7uF and is in parallel to a 47uF electrolytic on the Vin line supplying a voltage regulator. There is another 4.7uF cap in parallel, but is 2-3" away.
                    Thanks!
                    T
                    • neilc6
                      • Nov 2015
                      • 1550
                      The caps are for filtering noise on the supply voltage rails for each regulator and are placed next to each IC. Will work without it but if you want to replace it, Digikey ships USPS to US with no min or Ebay may have sellers that ship small volumes.
                      • alfatv
                        • Sep 2020
                        • 353
                        T
                        This cap is at input of buck regulator.
                        Without it:
                        - regulator operation may be unstable
                        - electrolytic cap next to it will be stressed
                        - unwanted electromagnetic (radio) interference is created
                        If possible, use larger size (physically bigger, not capacitance) capacitor with voltage rating of 25V or more.
                        There are some not populated caps in parallel, you can install those too, more is better.
                        • tbsmith
                          • Sep 2016
                          • 22
                          Thanks for the info and explanations! I found a 6.7uF SMD cap that is a little bigger physically, but was able to solder it in. All back together and ready for duty. Hopefully the difference in capacitance isn't going to be a problem...if so, should I just remove it and go without?
                          Ya'll are great!
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • RetroComputingGrotto
                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                            by RetroComputingGrotto
                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                            What component(s)...
                            02-03-2025, 06:00 AM
                            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                            by sam_sam_sam
                            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                            I tested the battery cells there are installed right now and they are testing good with no issues that I...
                            02-04-2025, 08:08 PM
                          • DynaxSC
                            Extreme High Current & Low Voltage Short Killer ??
                            by DynaxSC
                            Hi Folks
                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                            After taking off the socket, the shorts dissappear again.
                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                            10-15-2024, 10:13 AM
                          • harp
                            high voltage high resistance marking resistor
                            by harp
                            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                            08-26-2024, 01:42 PM
