panasonic tx-p42gw30S SN board problem
  • dj01fad
    • Sep 2014
    • 92
    • romania
    Hello there.
    Yesterday I bought this TV for a good price, and the seller told me that it goes into steady green and has no image.
    After a first test, I discovered the SN board shorted. so... I removed the power cable from the SN board, and surprise, 7 red blinks after. After the sc20 removal, it had 8 blinks, so I guess that the A board is fine.
    My question is... why it goes into steady green with the SN shorted?! Did someone else had this situation? For me it's a strange thing.
  • tw2005
    • Oct 2011
    • 6458
    Re: panasonic tx-p42gw30S SN board problem
    Originally posted by dj01fad
    Hello there.
    Yes, on a TNPA5351 in a P50U30A. It is mentioned in some of the guides as possible, assume you have 4 shorted 30F131?
    • tw2005
      • Oct 2011
      • 6458
      keeping in mind we have green flashing , solid green startup running , red solid standby.
      So sub green solid, no blink for the second note.
      Red Solid LED (No Blink): LSI error. This condition is triggered when the power supply SOS-detect-signal is triggered during the startup process.
      Shorted Vsus Shorted Vda Shorted P15V, SC(SN , SS most common
      • dj01fad
        • Sep 2014
        • 92
        • romania
        hello
        yes, 4 shorted, but they are dg301, not 30f131. I am out of stock, but they are on the way to me. I ordered some FGD's, regardinng the 30f131 fake issue.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Are you going to use the FGD's in place of the dg301's?
          • dj01fad
            • Sep 2014
            • 92
            • romania
            yes. is there a reason not to use them?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              I can NOW confirm that a FGD4635 can sub for a DG302. I did one this morning and it's still running after 7 hours. I also used four of them to replace the usual four igbt's.
              Hope this helps!!!
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                The model number was TC-P42S30.
                • dj01fad
                  • Sep 2014
                  • 92
                  • romania
                  yesterday I received 6 30f131 from panasonic service, and I've repaired the board. it is working perfect.
                  I am still waiting for the fgd's...
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    Today I got a 43" Samsung plasma for $20. It had the 4 shorted ibgt's on the x main. I used the FGD4536's in place of the RJP30H1DPD. Tv is working 6 hours later.
                    I love these things!!!!
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      The tv is still working as it should. Got to love the FDG's for only 50 cents a piece!
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        FDG's are alot more reliable tbh than the 30F etc series from what Ive seen.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          I think half the trouble is--there's just SO many Fake 30F devices around!
                          TELEFIX
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • modtool
                            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                            by modtool
                            Hi to all,
                            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                            04-01-2025, 08:22 AM
                            by sam_sam_sam
                            After all of...
                            07-13-2024, 08:14 PM
                          • Yanleb
                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                            by Yanleb
                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                            D608, good
                            D618 RF101L4S, good (See warning 1 below)
                            D619 RF101L4S, good (See warning 1 below)
                            D865 RF101L4S, shorted (See warning 1 below)
                            IC464 Inverter HA MC74HC1G14, shorted...
                            03-09-2020, 12:00 AM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
