Panasonic TX-P42ST30 with exploding diodes....
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TX-P42ST30 with exploding diodes....
    No , black and red prope both on white prong connector. One way it will beep for 1 or 2 seconds. Other way around it won't beep.
    A shorted board will beep constant.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      It will beep for about 2 seconds. Then if you reverse the meter leads it will beep for 2 seconds. If it stops beeping both ways, thats a good start. Dont forget to reflow all the screw hole grounds!
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        As Tvtimmy said , both side beep is not good. A good board will beep shortly on 1 side and no beep on the other side. ( black/red propes ).
        • satinser
          • Oct 2012
          • 214
          I take it you've tested for short across C842. If present at least one of the buffer chips will be shorted. This I believe also can cause the demise of the trio of SMD diodes D430, D432 and D433. In my case thats exactly what I found buffer chip IC4806 blown and that Grey stuff that Panasonic put around the buffer chips is awful to remove!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Our old friend flocko knows a good method of easily removing the buffer silicon on panasonics
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #26
              I found a solution for the exploding diodes on a TNPA5330 AB board.
              Common failure is that after replacing the 6 FETS ( Q401/402/403/421/422/423 ) the diodes D433/432/430 will explode. The 2 small resistors ( 40K Ohm ) will give a high value or will read short.
              The reason is fake parts! I replaced all fets with FGD4536 and replaced the diodes + resistors from a scrap board but it still blew up.
              I found out that both DG302 were also short. One is located on Q441 ( Under heatsink and will read short on both legs ) and the other is Q451 which will read short on 1 leg. Well atlas in my case.
              I replaced all parts including IC502 + Q531 with original parts and the board is back alive. Watch out that there are fake DG302 / RF1501 / 30F131 and RJP30H2A on ebay!! If the logo is almost gone using nail polish remover then you might have fake part.....
              Hope it helps someone.
              • matyka
                • Jan 2015
                • 179
                • Uk
                #27
                Hi,anyone could help me to fix my tnpa5330 board .I have removed all the shorted Fets .
                I have shorted diode near the Buffer IC. See photo
                Is this would be normal ? I have measured out the board and are all Ok .
                • Dvsr
                  On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                  by Dvsr
                  Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                  I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                  After replacing the caps I started testing out the speaker. It seemed...
                  09-10-2025, 10:20 AM
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                  11-20-2024, 08:52 PM
                • AquaMan Ua
                  by AquaMan Ua
                  05-17-2025, 09:40 AM
                • Nikolai Danylchyk
                  Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                  by Nikolai Danylchyk
                  Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                  Thanks in advance!...
                  05-08-2025, 06:18 AM
