Panasonic TX-P42ST30 with exploding diodes....
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TX-P42ST30 with exploding diodes....
    No , black and red prope both on white prong connector. One way it will beep for 1 or 2 seconds. Other way around it won't beep.
    A shorted board will beep constant.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      It will beep for about 2 seconds. Then if you reverse the meter leads it will beep for 2 seconds. If it stops beeping both ways, thats a good start. Dont forget to reflow all the screw hole grounds!
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        As Tvtimmy said , both side beep is not good. A good board will beep shortly on 1 side and no beep on the other side. ( black/red propes ).
        • satinser
          • Oct 2012
          • 214
          I take it you've tested for short across C842. If present at least one of the buffer chips will be shorted. This I believe also can cause the demise of the trio of SMD diodes D430, D432 and D433. In my case thats exactly what I found buffer chip IC4806 blown and that Grey stuff that Panasonic put around the buffer chips is awful to remove!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Our old friend flocko knows a good method of easily removing the buffer silicon on panasonics
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #26
              I found a solution for the exploding diodes on a TNPA5330 AB board.
              Common failure is that after replacing the 6 FETS ( Q401/402/403/421/422/423 ) the diodes D433/432/430 will explode. The 2 small resistors ( 40K Ohm ) will give a high value or will read short.
              The reason is fake parts! I replaced all fets with FGD4536 and replaced the diodes + resistors from a scrap board but it still blew up.
              I found out that both DG302 were also short. One is located on Q441 ( Under heatsink and will read short on both legs ) and the other is Q451 which will read short on 1 leg. Well atlas in my case.
              I replaced all parts including IC502 + Q531 with original parts and the board is back alive. Watch out that there are fake DG302 / RF1501 / 30F131 and RJP30H2A on ebay!! If the logo is almost gone using nail polish remover then you might have fake part.....
              Hope it helps someone.
              • matyka
                • Jan 2015
                • 179
                • Uk
                #27
                Hi,anyone could help me to fix my tnpa5330 board .I have removed all the shorted Fets .
                I have shorted diode near the Buffer IC. See photo
                Is this would be normal ? I have measured out the board and are all Ok .
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                  11-20-2024, 08:52 PM
                • AquaMan Ua
                  by AquaMan Ua
                  05-17-2025, 09:40 AM
                • stecos
                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                  by stecos
                  Hi everyone!
                  For my passion for technology I'm now collecting several...
                  11-28-2022, 11:39 AM
                • Fontana
                  BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
                  by Fontana
                  1. gΒ΄day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
                  2. if
                  12-18-2023, 05:45 AM
