LG Flatron W1946 wiring inverter AIP-0198
  • mehatronic
    • Oct 2016
    • 11
    • Croatia
    my problem:
    I need schema inverter to monitor.
    Flatron W1946
    Power chip -3BR1765JZ
    CCFL inverter -MP10072ES
    Mosfet -APM4511GED
    inverter no voltage on the output of the lamp
    Power works and have all the necessary voltage connector.
    I can not find a scheme inverter chip MP10072ES
    I looked at the service manual "LG" for this model but in the scheme only for VGA module-inverter for no
    would be very grateful if anyone has Schema or advice chip is compatible with MP10072
    thank you
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG Flatron W1946 wiring inverter AIP-0198
    There's a video on a similar model
    https://www.youtube.com/watch?v=l-Ge0qIlabI
    • mehatronic
      • Oct 2016
      • 11
      • Croatia
      ok,
      thank you for web address
      I know about it and all I tried
      capacitors are tested on capacity and% damage
      still need Schema inverter with chip MP10072
      regards
        Are you getting the INVER-ON (or BL-ON) command signal from the Main logic board to turn on the backlights inverter circuit?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8325
          Are the backlights totally dead or do they flash on for a second when you turn on the TV?
          • mehatronic
            • Oct 2016
            • 11
            • Croatia
            CapLeaker:
            sorry I did not for some time now (forum)
            flash a second
            I solved it with a new pipe By changing CCFL
            but still has a problem
            I get a picture on the screen, raise the Windovs all ok
            turn off the PC and turn on again when you can not pick up the image windowsa-
            flashed lights, logo appears, "LG", and the fit-not hold up a picture of the PC Windovs
            when you disconnect the flat cable with a VGA module on the LCD screen has a bright screen
            • x_orange90_x
              Vizio E55-E1 bad backlights or bad inverter?
              by x_orange90_x
              I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
              I don't know how exactly to test the inverter itself. Is it...
              01-29-2025, 09:24 PM
            • Gentian
              APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
              by Gentian
              I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
              It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
              03-06-2023, 07:07 AM
            • valvashon
              Insignia NS-LCD19-09 (PS OK, Inverter problem?)
              by valvashon
              For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
              History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
              01-04-2024, 01:44 PM
            • eccerr0r
              A modified sine wave inverter + a grid tie inverter?
              by eccerr0r
              If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
              Next thing is trying to charge the batteries using solar power, but that's another issue ...
              08-31-2023, 09:14 PM
            • caseyjay_48
              Sony KDL-46BX450 Inverter Troubleshoot Logic
              by caseyjay_48
              I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
              I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
              09-23-2022, 08:08 PM
