Panasonic TC-P50GT30 - Resistor Value on SC board
  • jason123
    • Oct 2015
    • 1143
    Rookie mistake - I know.. I'm hoping one of you Gurus can help me out.. I was working on the SC board (TNPA5335 SC) of a Panasonic TC-P50GT30, and the soldering iron slipped and I accidentally knocked 2 small resistors off the board.. I found one, but I can't find the other one. I would be grateful if some one can tell me the value of Resistors R588??? or just read off the numbers?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50GT30 - Resistor Value on SC board
    what were you doing poking around there?
    22K ohms
    Of course if you simply went to the service manual and located it in the spare parts list that too would tell you.
    R16588 D0GB223JA065 M 22KOHM,J,1/10W
    • jason123
      • Oct 2015
      • 1143
      Thank you so much tw2005. I couldn't find the service manual / schematic for that board. I was replacing the Transistors above that area and one was stubborn and I pushed it with the soldering iron a bit too much and knocked off these resistors.. Thank you again
      • tw2005
        • Oct 2011
        • 6458
        Just a google for the manual should bring up elektrotanya or other links, but I'm sure it's been uploaded here several times but would be handy if there was a way to search uploaded files within badcaps, would also reduce the need to attached the same files over and over again.
        yeah, I'd avoid force;. Will end in tears when you start destroying tracks.
        not sure what you're using but I get away with a 40W iron, medium chisel, I cut the legs and flow fresh solder onto the tab and let the heat soak. it'll start bubbling on the sides and when molten it'll come off quick.
        If you got hot air that could assist in heating the area as the tabs soldered to the board act as heatsinks so patience. Once the board gets hot around that area the other two are generally easier.
        • jason123
          • Oct 2015
          • 1143
          Great tips.. thank you tw2005.. you're a great help!
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ugamazing
            Assistance with identifying resistor value on 820-02918 A2992 board?
            by ugamazing
            Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
            I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
            09-06-2024, 08:33 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
