LCD TV won't turn on. LED keeps blinking
+ More Options
Posts
  • sahan14
    • Oct 2016
    • 52
    • sri lanka
    #41
    Re: LCD TV won't turn on. LED keeps blinking
    do i test the 450v cap again?
    • vinceroger69
      • Mar 2012
      • 6714
      #42
      yes put the psu back in the tv connect it all up as how it should be and carfully test voltage across that capacitor again
      • sahan14
        • Oct 2016
        • 52
        • sri lanka
        #43
        320v in 450v cap
        is it bad?
        • sahan14
          • Oct 2016
          • 52
          • sri lanka
          #44
          GND of primary and secondary circuits are not connected. Is it a fault ?
          • vinceroger69
            • Mar 2012
            • 6714
            #45
            i would of thought it should be slighty higher when the pfc circuit boosts the voltage up although the 450v on the capacitor is the maximum it can take it does not mean it should be 450v ive been trying to find a service manual for the tv but no luck as yet hopefully budm will have a read of this thread and have a idea what too check next as im still learning myself too ive attached a data sheet for one of the ics in your previous posts but cant find a data sheet for the other on, so bear with us im sure a more experienced members will advise on some more tests you can run soon.
            • culcuhain
              • May 2016
              • 186
              • U$@
              #46
              make sure you are using the legs of the capacitor to check the voltages for the large caps.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #47
                so you have fitted the new correct fuse to the psu then used the dim bulb tester and buld flashed and went off? if thats the case we can start testing voltages again we need to see why the boosted voltage is not there i have found a data sheet for the larger ic but cant seem to find one for the 230d6 ic
                I believe that these are the data sheets needed.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #48
                  Are you able to confirm the DC voltage across the large capacitor when switched on out of standby.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #49
                    im sure he tested that a few posts back now hes repaired the blown fuse it was 320v ive never worked on the pfc circuit so im still learning too from you guys as what too test next etc
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #50
                      Test the voltage on the VCC pin of the L6559 very carefully.
                      The DC voltage between Pin12 (VCC) and ground (negative leg of large capacitor) should be 10 -11.5V at turn on with a maximum voltage of 16V
                      • sahan14
                        • Oct 2016
                        • 52
                        • sri lanka
                        #51
                        I checked the ic
                        • sahan14
                          • Oct 2016
                          • 52
                          • sri lanka
                          #52
                          yes i checked the legs of the cap.
                          • sahan14
                            • Oct 2016
                            • 52
                            • sri lanka
                            #53
                            thank you barton for the files
                            • sahan14
                              • Oct 2016
                              • 52
                              • sri lanka
                              #54
                              i checked the output pins and there is no voltage. (white pins)
                              • sahan14
                                • Oct 2016
                                • 52
                                • sri lanka
                                #55
                                yes i switched on and tested the voltage. its around 325v
                                • sahan14
                                  • Oct 2016
                                  • 52
                                  • sri lanka
                                  #56
                                  i checked the ic
                                  VCC and the GND are connected (both are GND) :o
                                  there are some issues i checked the board
                                  a diode and transistor connected to GND line. (both sides)
                                  i cant find, where is the short or the bad component.
                                  • sahan14
                                    • Oct 2016
                                    • 52
                                    • sri lanka
                                    #57
                                    both pins are GND
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #58
                                      im not sure what your checking you need to test the ic by putting negitive multi meter lead onto negitive side of the large capacitor and then the red multimeter lead onto pin 12 of the ic and take the voltage reading be carfull not too let the probe slip as can short out small pins easily ive marked the ic you should be checking with a yellow outline
                                      • sahan14
                                        • Oct 2016
                                        • 52
                                        • sri lanka
                                        #59
                                        is it okay, VCC and the GND in the IC..... are both connected to common ground line?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #60
                                          see above edit ive made is that the ic your testing?
                                          • mar1in
                                            LG UH652T doesn't turn on and stands is blinking once a second
                                            by mar1in
                                            I've got this LG TV here that wouldn't turn on and be stuck in a standby loop (blinking red once every other second).
                                            Did test the following:
                                            * LED's seem fine as they all light up using LED Tester
                                            * Power Supply supplied around 111V for each LED Strips (2x edge lid strips)
                                            * PWR_ON would be at around 3V but dropping every other second (just like the standby light)
                                            * DRV_ON is doing the same
                                            * power supply has a green LED onboard, but that doesn't seem to do anything (stays off the whole time).
                                            * there is a tiny clicking...
                                            11-10-2024, 06:23 PM
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • my dodge
                                            HP ZBook 17 G3 Mobile Workstation LA-C391p won't turn on and the power light is blinking
                                            by my dodge
                                            Hello
                                            I was looking for a schematic or board view but unfortunately I didn't find anything.
                                            By connecting the drain and source of pq58, the device turns on and works perfectly, but the battery doesn't charge, and I don't know the path of the circuit to the MOSFET.
                                            Is the problem with the adapter? Or is there a problem with the MOSFET activation circuit?
                                            Please guide me.
                                            Thank you.​
                                            12-12-2024, 08:37 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
