Sharp LCD screen noise
  • jurgyman
    • Jul 2015
    • 27
    I have a Sharp LC-32D62U
    the screen constantly has a grid of noise
    in TV,hdmi4, hdmi5, doesnt matter.
    Power board caps look good.
    pulled the main board.
    Looked for any cold solder joints, couldnt find any.
    any advice?
    JM
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Sharp LCD screen noise
    With no signal input is the screen clear of noise?
    • jurgyman
      • Jul 2015
      • 27
      It happens no matter what the input selected.
      IE, on an hdmi with no signal, see the noise.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Image of Tcon/boards ? Im aware some sharp Tcons are prone to failed bga solder causing similar symptoms or could even be as simple as lose Lvds cable.
        • mmartell
          • Oct 2013
          • 3189
          Heat up the main board with a hair dryer.
          • 102mm
            • Dec 2013
            • 181
            • us
            I had a 52" version with the same issue. it used a different main board though. I baked the main board in the oven and it fixed the issue for about a month. The issue now happens when you first turn he TV on but eventually goes away.
            Craigslist Picks & Fixes
            2 ea - Samsung 52"
            Samsung 60"
            • jurgyman
              • Jul 2015
              • 27
              what temperature in the oven and how long?
              • mmartell
                • Oct 2013
                • 3189
                That's a last resort. Heat it up with a hait dryer first to see if that affects your issue. A hair dryer won't hurt it but an oven surely can.
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • EazyBone
                  Sharp LC-65Q620U White Screen
                  by EazyBone
                  Another TV topic!!
                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                  08-21-2024, 12:56 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • Mad_Science
                  Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                  by Mad_Science
                  I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                  03-01-2024, 05:05 PM
                • scubacamper
                  Sharp Aquos LC-70C6400U Half Screen Dark
                  by scubacamper
                  I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                  Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                  when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                  05-03-2025, 12:19 PM
