M55-C2 Inverted picture.
  • BENSELECT
    • Aug 2010
    • 12
    Hello this is my 1st post to this forum so bear with me.
    I have a Vizio M55-C2 that I originally received as dead. It had received a surge thru the HDMI port.
    I replaced the Digital main BD and set worked great but the picture and menu's are upside down.
    I originally thought setting in the service menu but none of the procedures for entering the service menu posted on this forum will work on this set.
    I have never experienced this before but other post suggested T-con board so I gave this a try. Still upside down.
    I returned my digital board suspecting corrupted eeprom and order new one and new board also has inverted picture and menus.
    I am back to square one trying to enter service menu. Does anyone have any experience with this model set?
    These are the procedures I have tried.
    1. Turn The TV off.
    2. Press and hold the {CH +} & {CH -} buttons on the TV.
    3. Then press and release the {POWER} button on the TV.
    4. Release the {CH +} & {CH -} buttons.
    5. Now press the {MENU} button on the remote.
    6. You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
    7. Press and hold the {MENU} button for few seconds.
    8. The Service Menu will be displayed.
    Vizio Service Menu Method 2
    1. Turn The TV off.
    3. Then press and hold the {POWER} button on the TV.
    4. Keep all three buttons pressed for few seconds.
    Vizio Service Menu Method 3
    1. Press and hold the {EXIT} button on the remote for 3 seconds then release it.
    2. Then press the {1} {2} {3} buttons on the remote.
    3. To exit, press the {EXIT} button.
    GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
    VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
    VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
    Push "Menu" on remote and then push "Vol-" and "Input" on keypad
    GV46 / P50HDM / P50HDTV10A
    Press "Ch-" and "Ch+" buttons together once on keypad
    GV42 / L42 / VP42HDTV10A / VP50 / VX37
    Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
    P42
    Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
    VM60P
    Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
    The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
    GV47
    Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
    SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
    VO320EP8 / VO370M / VO420E / VP504 / VP505
    Press "Menu," and then press "2," "4," "8," "9."
    VA19 / VA22LF / VA220E / VA26
    Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
    VA320E / VA320M / VA370M / VT420M / VT470M
    Press "Menu" and then press the following combination: "1," "9," "9," "1"
    VW22 / VS370E
    Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: M55-C2 Inverted picture.
    Reload correct firmware for the tv should fix the issue
    • BENSELECT
      • Aug 2010
      • 12
      You can not download firmware for these sets. But it automaticly installed the latest firmware last night.
      • BENSELECT
        • Aug 2010
        • 12
        These sets will only automaticly install firmware when the set is off and connected to the internet. There is no option to manually install firmware nor does Vizio offer it on there web site.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Not sure if you set has this feature. Go into Service Mode and see if there is a 'control' option which would take you to the 'configure' option then to the 'HV Fli' option....If it is OFF turn it ON and if is ON turn it OFF.
          • BENSELECT
            • Aug 2010
            • 12
            We need to figure out how to get into service mode on this set first. But yes that is the setting I am looking for.
            • Lsserblast
              • Oct 2016
              • US
              I know the answer to this. Some of these TVs come with an AUO panel, and some with a Samsung panel. The panels are mounted/driven in opposite 180 degree configurations. So if your TV originally had an AUO panel and you replaced your motherboard (marked as "MB" on the ribbon cable) with one from a Samsung panel, the picture will be upside down because the motherboard expects a Samsung panel (rotated orientation). I suspect there's a jumper or resistor on the motherboard somewhere that tells the firmware what panel is connected and what the picture orientation should be, but I don't know where it is or if it even exists. If it helps, the AUO version of the M55-C2 motherboard has a heatpipe and supplemental heatsink whereas the Samsung version does not (if you try to find a proper replacement). The AUO/Samsung LCD driver boards are not interchangeable, as the ribbon cables have a different number of conductors/wires. There may also be other hardware revisions I'm unaware of. Hopefully this helps someone working on these TVs!
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                So did it correct the upside-down image?
                • BENSELECT
                  • Aug 2010
                  • 12
                  Problem was never fixed.
                  Could never find out how to enter service menu.
                  Customer just took it home an mounted it back on the wall upside down and was very happy.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Good solution applied by Customer...Final analysis...Customer happy...Case closed.
                    • ecking767
                      • Oct 2009
                      • 492
                      you may have the wrong main board install, did you order by the exact part number?
                      • petehall347
                        • Jan 2015
                        • 4445
                        • United Kingdom
                        i suggest things like this for fun .. i was never aware it really happened .
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Well whatever works for ya
                          • attainteddragon
                            • Apr 2013
                            • 764
                            • australia
                            think of it this way, if it is wall mounted high enough, then you can't see the stand hole, so it is aesthetically pleasing.
                            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              Well you can always put a flower pot with a plant to cover the stand hole.
                              • IK74
                                • Mar 2014
                                • 7
                                Not sure if some of the information above is accurate. I have M55-C2 with AUO screen and and main board "without" heat pipe. Although I am not the first owner I doubt the screen or mainboard was ever replaced. My TV serial number starts with LWZASBBR. Based on shopjimmy web site TVs with serial number starting with LWZASBBR use main board without pipe (that's also what I have). TVs with serial number LWZASBAR use main boards with heat pipe. Perhaps Lsserblast got these two mixed up..
                                My tv has black screen and standby light blinks 15 times. Does anyone has any tip besides replacing the main board? Does anyone know what 15 blinks mean? Anyone repaired it on component level? Thanks.
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                • Woodsworth
                                  PS3 CECHC03 60GB YLOD Troubleshooting
                                  by Woodsworth
                                  I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                  START
                                  Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                  03-19-2024, 07:58 AM
                                • RRice25541
                                  Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                  by RRice25541
                                  So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                  the color is all outa wack, like the settings have been corupted,
                                  I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                  so
                                  The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                  when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                  05-13-2022, 10:44 PM
                                • Robby-Gr
                                  TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                                  by Robby-Gr
                                  I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                                  However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                                  The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                                  Additional issues:...
                                  09-27-2025, 12:02 AM
                                • Retro140
                                  Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                  by Retro140
                                  So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                  To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                  06-18-2023, 06:13 PM
