PSU with FAN8754 won't torn on
  • fejlong
    • Dec 2013
    • 55
    • United Kingdom
    Re: PSU with FAN8754 won't torn on
    At the other end of the series resistor-diode I measured 102.4V DC regarding to IC ground pin 1
      Looking at the pictures:
      https://www.badcaps.net/forum/attach...6&d=1474884739
      So what happen to the diode and the two resistors connected to pin 4 for the HV pin, some one replace those parts? D101 R102, R???
      • fejlong
        • Dec 2013
        • 55
        • United Kingdom
        Yes, replaced them. But no change
          What ACV are you getting at the Anode of D101 ref to GND pin of the IC?
          • fejlong
            • Dec 2013
            • 55
            • United Kingdom
            At D101 anode is 119V AC regarding to ground.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              I'm wondering if the mains input supply which should be 230V is low. In post #1 it was reported that there was 300V DC across the HV capacitors but I think it should be about 325V which may be why the HV voltage at pin 4 is just below the minimum Brownin voltage.
              • rievax_60
                • May 2012
                • 897
                • australia
                #27
                The 2v on the FB pin 2 is close to the possible zero duty threshold. There could be a leaky component on pin 2 or the optocoupler is being turned on. What is the LED voltage?
                • fejlong
                  • Dec 2013
                  • 55
                  • United Kingdom
                  #28
                  Leaky component, you mean caps ?
                  The only cap on that line is C112 - 4u7 / 50V I don't know his role.
                  The multimeter cannot measure resistance on this cap, nor capacitance. I will desolder it to check it more thouroughly.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #29
                    I was talking about pin 2 of the IC, U101. Do a resistance measurement to live ground (pin 1) first. Do not try to apply power with any pin of the optocoupler disconnected.
                    What is the voltage across the opto's LED pins?
                    • fejlong
                      • Dec 2013
                      • 55
                      • United Kingdom
                      #30
                      Resistance between pin 1 and 2 of IC U101, with no power applied, is 100 Ohms.
                      Voltage drop on optcoupler pins 1 and 2 is 1.05V
                      With power on, led voltage of the optocoupler between pin 1 and 2 is 1.05V .
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #31
                        The bit that doesn't make sense is the 1.05v across the opto's pins 1 and 2. Is that with no power applied also? Do you measure any voltage at the 24v output?
                        I should have mentioned that we don't normally make resistance measurements with power applied. It is not safe for you and the TV. You must have had power applied to get the 100 ohm reading.
                        • fejlong
                          • Dec 2013
                          • 55
                          • United Kingdom
                          #32
                          I was not fully understanding you question in post nr 29, so I measured voltage between opto's pin 1 and 2. It results 1.05V with power applied and Pson.
                          And also desoldered pin 1 and 2 of the opto, and with the meter set to diode test, it shows 1.05V voltage drop. I also measured other opto's wich I have as spare, they all read about the same 1V.
                          At the 24V output I can measure 3V.
                          There is also a ratling sound from the transormer, it's about 6-10 Hertz.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            From the information supplied the voltage across the capacitor indicates that the PFC circuit is not operating.
                            The voltage at the HV input (94.5V) is below the minimum threshold (104V) to maintain the PWM output drive of the FAN6754. However, these figures are given in the data sheet for a 200K resistor/diode combination and not 156K/diode combination as in this circuit.
                            The VCC (pin 7) is at 18.5V. D103 connected to the VCC input to ground is an 18V Zener so that voltage looks correct. This voltage is generated by U201 (VIPER17) which also supplies the 3.3V standby which is also present.
                            You could lift out diode DS1 to isolate any problems with the 24V supply side and check if voltage at Vb rises > 300V.
                            Can’t think of anything else at this time.
                            • fejlong
                              • Dec 2013
                              • 55
                              • United Kingdom
                              #34
                              PFC ? You mean Power Factor Corrector ? I don't know if this has any PFC
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #35
                                The 1.05v across the LED indicates that it is passing forward bias current and emitting light causing the opto's internal transistor to turn on, in turn causing U101 to throttle almost fully down. There will be bursts of very brief pulses applied to he MOSFET's gate causing the rattling and very little power flow through the transformer.
                                The circuitry involving the TL431 and the opto's LED isn't supposed to turn on the LED until the output has climbed to 24v.
                                Difficult to figure out the reason without an understanding of how the TL431 works. Do some research on the TL431. Never apply power while the regulation loop is open. The output will go over voltage and cause more damage. That capacitor you circled can possibly be the cause if leaky.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  OK, with DS1 removed what is the ac voltage at Pins 9 & 10 of TS1
                                  • fejlong
                                    • Dec 2013
                                    • 55
                                    • United Kingdom
                                    #37
                                    Pins 9 and 10 are joined. if you mean output of the transformer coils, is zero volts. And the rattling disappeared, the feedback killed the supply totally. I will try study TL431 on this board to see what causes the high feedback. Thank you rievax_60 , i will be back with the feedback
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #38
                                      Doing that will likely cause the MOSFET to fail.
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #39
                                        I hope that you did not remove DS1 and apply power?
                                        • fejlong
                                          • Dec 2013
                                          • 55
                                          • United Kingdom
                                          #40
                                          Actually I removed only 1 pin, the cathode. Nothing happened as i can see. Soldered it back, and still rattles.
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • Nooy
                                            VGA MOSfet permanently shorted and loss of MOSfet pad
                                            by Nooy
                                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                            02-14-2024, 02:26 AM
                                          • redbaron1007
                                            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                            by redbaron1007
                                            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                            09-09-2025, 11:10 AM
                                          • AppleLover123
                                            Asus X712EA 3 volts after the first mosfet
                                            by AppleLover123
                                            Hey guys,
                                            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                            Now i thought something...
                                            12-15-2024, 07:49 AM
                                          • MicroSMD Lab
                                            ASUS ROG Zephyrus GPU Mosfet repeat failure
                                            by MicroSMD Lab
                                            The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                            01-10-2024, 06:36 AM
