The picture on my Vizio VX32LHDTV10A intermittently scrambles and then comes back after awhile. But then would scramble again eventually. I was going to order a new main board or T-Con board but the part number shows a (4C) at the end. I have not been able to locate the part with the (4C). The number is 3632-0162-0150 (4C). I am wondering if a part number with a different number in parenthesis at the end will work? Also, is it possible there is some other issue causing this problem? How do you recommend I troubleshoot this problem?
Vizio VX32LHDTV10A Intermittent scramble of picture
Re: Vizio VX32LHDTV10A Intermittent scramble of picture
I have a Vizio M421VT that had a scramble pic but all the time not intermittent and i've got this Vizio Running, i did the BGA chip heating,The picture on my Vizio VX32LHDTV10A intermittently scrambles and then comes back after awhile. But then would scramble again eventually. I was going to order a new main board or T-Con board but the part number shows a (4C) at the end. I have not been able to locate the part with the (4C). The number is 3632-0162-0150 (4C). I am wondering if a part number with a different number in parenthesis at the end will work? Also, is it possible there is some other issue causing this problem? How do you recommend I troubleshoot this problem?
i applied heat with a heat blower, the same method as the Ps3 YLOD fix tutorial, just by heating first bottom side with low heat then with high heat the heat sink on the main board BGA heat sink , let it cool for an hour then put it together and voila it was running,then for feature caution i opened a big hole behind the Main board Heat sink, and added 2 small 5 v fans connected to USB. It's been working good for about a year now,don't know if this is the same issue of yours but it's worth a try, if need more info just ask or pm me.
This is your main board BGA MT5372AJ M ARM you don't have heat sink like mine so use heat on medium for less time
http://assets.shopjimmy.com/media/ca...0150-top_1.jpg
https://www.youtube.com/watch?v=J5fzUrP0pxs
https://www.youtube.com/watch?v=YiSs0lPw6RYLast edited by ivtec; 09-25-2016, 02:58 PM.Comment
Overheating is something that occurred to me. I watched your Youtube video for fixing Playstaion units. Thanks for the tip. Never considered heat flowing. On a TV board though I am not sure they even put something like Arctic Silver on the GPU. There is a metal plate mounted on top of the main board so I am wonderring if that is causing overheating. The link of the part is exactly like the board I pulled. Except it has (4B) instead of (4C). Do you think the (4B) will work?I have a Vizio M421VT that had a scramble pic but all the time not intermittent and i've got this Vizio Running, i did the BGA chip heating,
https://www.youtube.com/watch?v=YiSs0lPw6RYComment
The Video i posted was not made by me about PS3, but rather to let you know the proper way to use the Heat blower on the BGA on the main board of the TV,although the issue of either the BGA on the tv main board or the CPU of the P3 is that the over heat of BGA or CPU causes the solder joints to become cold solders then turning in bad connections inside the BGA or CPU.Overheating is something that occurred to me. I watched your Youtube video for fixing Playstaion units. Thanks for the tip. Never considered heat flowing. On a TV board though I am not sure they even put something like Arctic Silver on the GPU. There is a metal plate mounted on top of the main board so I am wonderring if that is causing overheating. The link of the part is exactly like the board I pulled. Except it has (4B) instead of (4C). Do you think the (4B) will work?Comment
Are you suggesting the method shown well fix the cold solders or should I replace the board? Maybe the method shown with a blow heater would be worth a try? But on a TV board BGA chip there is no heatsink and as far as I can tell no paste has ever been applied to what looks like the chip. Maybe even applying some Arctic Silver to the chip anyway would keep it from overheating.Comment
Well you could try to put a piece of aluminium on top of the BGA so when you use the heat blower it will not heat direct on the chip,since it has not Heat sink,Are you suggesting the method shown well fix the cold solders or should I replace the board? Maybe the method shown with a blow heater would be worth a try? But on a TV board BGA chip there is no heatsink and as far as I can tell no paste has ever been applied to what looks like the chip. Maybe even applying some Arctic Silver to the chip anyway would keep it from overheating.
try to use medium heat setting on the heat blower.
you have nothing to loose,
or you could buy it from ebay;
http://www.ebay.com/bhp/vizio-vx32lhdtv10a
Note; i said CPU on the Playstation 3,but in fact it's not a CPU chip like on most modern computers but A BGA like the one on my Vizio and on yours,
https://en.wikipedia.org/wiki/Ball_grid_arrayLast edited by ivtec; 09-27-2016, 10:47 AM.Comment
Good idea about the aluminum foil. I mostly have worked on PC's since the 90's so TV repair is pretty new to me. Was wondering what BGA actually means. With CPU's you actually use the cooling agent on the chip and then attach the heatsink with fan. Some have suggested using a hair dryer but I would think actually using a heat blower would be better as you can adjust the level of heat. One would sure not want to overheat the chip which I have done by simply not connecting the heatsink fan properly. Live and learn. I will give this a try and see what happens. It was very tricky though getting the board ribbon cables disconnected. Thanks again.Comment
https://en.wikipedia.org/wiki/Ball_grid_arrayGood idea about the aluminum foil. I mostly have worked on PC's since the 90's so TV repair is pretty new to me. Was wondering what BGA actually means. With CPU's you actually use the cooling agent on the chip and then attach the heatsink with fan. Some have suggested using a hair dryer but I would think actually using a heat blower would be better as you can adjust the level of heat. One would sure not want to overheat the chip which I have done by simply not connecting the heatsink fan properly. Live and learn. I will give this a try and see what happens. It was very tricky though getting the board ribbon cables disconnected. Thanks again.Comment
by gavricHello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
When tv powers on vizio V logo shows nice on whole screen. picture 1
When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
When i start youtube picture shows on left side fine, right is all scrambled. pic 2
When i click video to start playing picture goes black(like when you change... -
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
by maricmHI all,
hope someone point to the possible issue before I start buying replacement parts.
Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
Backlight stays on all the time,
Sound works fine.
screen keeps changing form black to full picture in about 1sec intervals.
Picture looks fine with no visible artifacts.
I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
Disconnecting left and right ribbons on... -
by csmithI replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
issue. Set will power up with remote but not power off.... -
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... - Loading...
