Philips TV with badly hissing Vestel 17IPS20P supply, any solution ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Greetings folks. I recently fixed this Vestel 17IPS20P power board inside a Philips TV (shorted output diodes that weren't even all the same >_>) and it's working fine now, except it's making this pretty loud and obnoxious hissing sound. It seems to be coming from that PFC coil (on the right next to the two red caps), though I might be wrong, since the noise is high pitched and hard to pinpoint. Usually such noises point to bad caps (the irony) causing lack of filtering, but without an ESR meter I can't go around changing EVERY cap on the board hoping the hiss would die down. I've already changed two of the 4 output caps, since they were rated at 16v and I put in 25v ones (the brown ones towards the right which are different from the 2 black ones next to them), but it didn't change anything. The noise starts when the TV is switched on and stops when it's switched off (DUUH). Its pitch doesn't change with the picture or backlight intensity. Has anyone experienced this ? Is it a cap issue at all ? Is it really that particular coil hissing, or is it the transformer next to it ? I'm perfectly aware it could be due to bad quality components, since these Vestel PSUs are absolute pieces of junk and it may be an inherent issue that you can't do anything about....
    Wattevah...
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Philips TV with badly hissing Vestel 17IPS20P supply, any solution ?
    not sure if you have a circuit diagram but this may help
    https://electronicshelponline.blogsp...d-circuit.html
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Try listen close to the Psu and see if its the transformers causing it.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Like I said, putting my ear as close as I safely could to the board, it seems to be coming from around that large coil, since there aren't any components in that area that could hiss. I tried using a plastic stick to tap and press some of the components, but not even the slightest change in the sound...could be a loose winding on a transformer or coil.
        Wattevah...
        • vinceroger69
          • Mar 2012
          • 6714
          i use a cardboard tube the type that comes inside of kitchen rolls etc or even one from tin foil etc that way you can place the tube over the parts and put your ear on the other end safely.
            https://www.badcaps.net/forum/attach...6&d=1474467079
            The two inductors to the right of the two read caps are the LINE filter, the PFC inductor is the TR100.
            So when TV is in standby do you hear the noise?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Like I said towards the bottom of my original post: no, when the TV is off the sound goes away. Also, I know those two identical coils are for line filtering and are not the culprit. The PFC coil is to the LEFT and down of the red caps in my picture.
              Wattevah...
                'Like I said towards the bottom of my original post: no, when the TV is off the sound goes away' Sorry I missed that section.
                  BTW, what is the PFC boosted Voltage are you getting, 400 VDC?
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Haven't checked that yet, but I think it should be close to that, since the TV is working properly.
                    Wattevah...
                    • Diah
                      • Feb 2013
                      • 6366
                      i faced before on Philips 40PFL5507 with Vestel PWB TV working fine but PWB make noise like over load . when i disconnected the LCD by moving out the ribbon cable it work silent but no picture of course..
                        I do not know what the PFC Under Voltage shut down point is on this VESTEL board, Typical for Samsung is about 350V, if the PFC Voltage is lower but not at shutdown point, the TV will still function but the current through PFC circuit will increase so that is one possibility that the PFC circuit is making noise.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Ok, but what could be causing such undervoltage ? Only those diodes I mentioned were busted - apart from that, everything seems fine.
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            After using the "paper tube stethoscope" method that vinceroger69 suggested, it turns out it's not the PFC inductor that's hissing, but instead the main transformer (the blue one). Indeed, when I press my finger on top of it, the hissing does change a bit. I've replaced MOST of the caps, except the long 200v ones, so it could be due to the transformer itself.
                            Wattevah...
                              There is feedback circuit that control what the Boosted Voltage output will be. If it is not low then that is not the problem.
                              • R_J
                                • 9535
                                You say you replaced shorted output diodes "(shorted output diodes that weren't even all the same >_>)" What were the original numbers and what did you replace them with?
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  Can't remember exactly, but of the 3 different types that were in there originally (all shorted but one), I chose the one with the highest ratings which I'm sure was an SB5100 so that's what I put in. No, the diodes don't go to different circuits - they all connect to the same trace on the back. They skimped out and didn't use TO-220 packs for some reason....
                                  Wattevah...
                                  • R_J
                                    • 9535
                                    I was just going by the diagram Budm provided and it has d207 and d208 (for the +24volts) as uf5402 which are ultrafast switching types
                                    Did you change those or only the ones for the +12 volts (d209,d210,d205 & d505)
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      The ones I replaced are the 4 ones above and the the right the blue transformer in my picture, so those would be d208, d209, d210 and d211.
                                      Wattevah...
                                      • R_J
                                        • 9535
                                        So all 4 are connected in parallel and only for one voltage? ( the diagram is a bit misleading)
                                        The UF5402 are rated with a trr speed of 50ns
                                        The SB5100 are rated with a trr speed of 500ns
                                        since those are the diodes you replaced and that seems to be where the problem is its posible the diodes are not switchng fast enough causing the transformer to make the noise it is.
                                        • Yrouel
                                          Philips 22PFL2908H/12 - Vestel 17MB62-1 - Possible to enable HDMI CEC?
                                          by Yrouel
                                          I have this tv for which I'd like to enable HDMI CEC (EasyLink as Philips calls it) if possible.
                                          The CPU/SoC should support it and I found about the possibility of customizing the TV behavior/functionality with the hardware and software profiles.
                                          I also got serial access to the TV through the SCART connector (side note how do you dump the firmware through that port?)
                                          I'm attaching everything I got about this TV: A zipped folder with various material like the profiles, a log of the boot process, a picture of the service menu, etc.; the service manual...
                                          05-23-2021, 06:59 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • Lisa Su
                                          Samsung P2250W Hissing (Newbie)
                                          by Lisa Su
                                          I've been using this monitor for last few years.
                                          Symptom started by OSD menu popping on and off randomly by itself. So i tried to clean the touch control area with some cloth but it didn't help.
                                          After 20 minutes monitor started hissing from the back. And then 30-40 seconds later screen started fade off/on like as if i was turning down the brightness that's when i turned it off by power button (hissing stops) and replaced it with spare monitor.
                                          Today i opened up the monitor, excited to repair my first monitor (or big electronics) hoping it's a bad...
                                          03-07-2022, 05:58 AM
