Philips TV with badly hissing Vestel 17IPS20P supply, any solution ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: Philips TV with badly hissing Vestel 17IPS20P supply, any solution ?
    Originally posted by R_J
    So all 4 are connected in parallel and only for one voltage? ( the diagram is a bit misleading)
    Should've taken a photo of the underside too. Actually, only 3 of them are in parallel - the fourth one goes somewhere else...can't remember the layout exactly, but I'm sure it's the one closest to the outside edge of the board that does this...might be the 5v tap of the transformer.
    Wattevah...
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • Yrouel
      Philips 22PFL2908H/12 - Vestel 17MB62-1 - Possible to enable HDMI CEC?
      by Yrouel
      I have this tv for which I'd like to enable HDMI CEC (EasyLink as Philips calls it) if possible.
      The CPU/SoC should support it and I found about the possibility of customizing the TV behavior/functionality with the hardware and software profiles.
      I also got serial access to the TV through the SCART connector (side note how do you dump the firmware through that port?)
      I'm attaching everything I got about this TV: A zipped folder with various material like the profiles, a log of the boot process, a picture of the service menu, etc.; the service manual...
      05-23-2021, 06:59 AM
    • France_53
      Vestel tv, how to flip the image?
      by France_53
      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
      05-12-2024, 05:22 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
