Curtis 3227A no Audio Issues
    Re: Curtis 3227A no Audio Issues
    Can you read the schematic? You also need to understand how that IC functions when it used in SE (Single Ended mode) and why it needs the DC blocking/coupling cap.
    The output pin of the power amplifer will sitting at 1/2 of the supply VCC, so if the power supply is 24VDC, then the output pin will be at 12V.
    As you see, if you hook up the speaker directly to the output pin of the IC, then you will be applying 12V to the speaker which you will damage the IC and the speaker, that is why you need the DC blocking/coupling cap between the output of the amplify and the speaker.
    if the has leakage resistance or shorted out then the cap will no longer block the DC to the speaker.
    If you trace out the + speaker wire to see if it is connected to one end of the cap, and another end of the cap goes back to the amplifier output or not. See PDF page 19 FIGURE 32 as a guide.
    you need to look at the spec sheet of the IC, then trace out the connection from the output pin of the amplifier all the way to the speaker connector.
    BTW, if you have 12VDC on the speaker terminal with the speaker connected then you have heard loud popping sound form the speakers.
    You should check the speakers if they are still OK.
    Notes: the amplifier in your TV is the Class D amplifier, the example below is the Linear amplifier but the outputs for both type of the amplifier with single power supply will have DC at the output, the DC blocking cap is also part of the high pass filter, see PDF page 14.
    http://reviseomatic.org/help/e-a-amp...Amplifiers.php
    • Diah
      • Feb 2013
      • 6363
      Originally posted by mike123333
      I did look for the obvious as to whether the internal speakers were on or off, I am presently using the rca audio jack to run from a dvd player.
      trouble shooting the sound by using out source audio signal more complex as TV signal as there many circuit switcher & main IC Digi signal detector / switcher.
      also to make it easy , first make hard reset for the TV, and plug it to RF signal as TV and make first install and Chanel search.. from this point we will have narrow the circuits involved with sound issue.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        You really need to work on your English or use something better then Google translator,I am trying really hard not to dislike you here.
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • mike123333
          • Oct 2011
          • 196
          When I viewed the spec sheet I did not look at the schematics further down to see the circuit layout. I did trace back the connection from the speaker to the cap and cap to the IC, they were all good.I double checked the capacitance and the ESR on the caps they were good and no shorts.
          In the process of removing the speakers and checking the functionality of the speakers I was having a little bit of trouble at first getting them to function with the wire connection, even with trying to get a good resistance read. I finally tested them offline and they both worked. I then placed the main board back into the TV and lo and behold they both worked. I thought at this point maybe there is bad connections(cold solder joint) on the speakers so I applied solder and reworked that in there.
          It turns out that this particular model does not have an audio out I was more referring to a second gen of this model manual instead of looking at the back panel and the description of the inputs and outputs. . So I am wondering now whether that is the issue with the speakers and cold solder joints or bad connections. At least now I understand that part of the circuitry.Thanks to every ones help....
          We will have to see how long they remain operational.
            So your TV does not have RCA audio line outs as shown in the owner manual that I found for your TV.
            Just keep an eye on it then and see what happen.
            • mike123333
              • Oct 2011
              • 196
              This particular TV I acquired from a friend. I downloaded the manual and kind of used that as my main go to regarding cabling. So when I got the speakers to work I looked at the layout of the inputs on the TV cover and then realized there is no audio outputs.
              After I thought more about it regarding the no audio now it makes sense to me about the lack of resistance from the speakers as I was troubleshooting and getting the 12V across the speaker terminal plugs. The speakers were not making good wiring contact.
              • samson7point1@yahoo.com
                Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                by samson7point1@yahoo.com
                The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                The player processes the audio signal using two different reference frequencies. The "R"...
                04-30-2024, 11:22 AM
              • SoulFreeze
                Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                by SoulFreeze
                Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                After repairing the above issue, I realized the following remaining problem,
                Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                The computer recognizes headphones are connected and displays a popup in windows
                Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                06-21-2025, 09:53 AM
              • i_am_patch
                Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                by i_am_patch
                Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                04-30-2024, 08:20 PM
              • MOSSEP
                Monitor Audio RSW12 - Green light but no audio
                by MOSSEP
                Hi
                Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                I have already tried replacing all of the...
                01-26-2025, 08:18 AM
              • grimacelord
                MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
                by grimacelord
                I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
                12-11-2023, 11:13 AM
