Another 60PV250 pic fault but different this time. Help greatly appreciated
  • jwarnes
    • Feb 2014
    • 29
    Had this one a while now. Great tv. Had usual bad inductor solder joints on Z board repaired with new fets and caps etc. Ran perfectly fine for another year! Then this new picture problem emerged. Checked all voltages and usual problems all good yet pic is still trash.
    Have a look at the photos.
    I cant figure out the reason for the black splotchy patches.
    It would be ok then appear when the tv warmed up.
    I have not mucked about with the Y board or buffers too much because the voltages all seem ok and the picture is mostly there.
    Does anyone have any clues what's going on?
    Cheers.
  • mmartell
    • Oct 2013
    • 3189
    Re: Another 60PV250 pic fault but different this time. Help greatly appreciated
    Not that I think it's the mainboard but run the test patterns.
    • jwarnes
      • Feb 2014
      • 29
      How do you put this one into test pattern?
      I cant see the 4 pins?
      Photo attached
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Looks like Zsus issue to me, whats Zbias at ?
        • jwarnes
          • Feb 2014
          • 29
          Thank you. Reevey can i just confirm with you first the correct way to measure the zbias?
          • jwarnes
            • Feb 2014
            • 29
            I will retest all the voltages and put them up.
            Vs 203.1v
            Va 55.1v
            Vzb 110.3v
            Vy -179.9v
            VSC 149.5v
            M5V 5.15V
            And if i change vzb up to 115 or down to 105 picture does not change.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm so it seems the Sus voltages are fine theres a chance the ERC could be low but unlikely as normally if that area fails you would get no image, try running the test patterns as MM said this is done by bridging the Auto exgen pads on the controller and removing the Lvds cable.
              • jwarnes
                • Feb 2014
                • 29
                So I've played with the TV picture settings in the menu and found it is greatly improved if i turn up the contrast to maximum.
                Ive repaired the zbias before and its running in spec which is why i don't think it is a z bias problem this time.
                • jwarnes
                  • Feb 2014
                  • 29
                  Is this the area i need to pay attention to?
                  • jwarnes
                    • Feb 2014
                    • 29
                    Theres a pot on the Y board that says (SET-UP)
                    What is that for?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Bridge the copper pads between R51 & R52 with Lvds removed to get test patterns.
                      • jwarnes
                        • Feb 2014
                        • 29
                        Test pattern images attatched
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          That's got to be a zsus problem.
                          Smarter people than me to reply soon.......
                          • jwarnes
                            • Feb 2014
                            • 29
                            Ive noticed the image is not good in normal mode viewing tv. Then if I go through the menu its still no good....untill that is when I get to the image wizard adjustment section where it goes to change the contrast. Two pics attatched. First one before and second pic after it suddenly switches to a vastly improved but not perfect picture.
                            Then upon exiting the picture wizard it goes back to extrememly poor picture and heaps of ghosting.
                            And I watched the vzb voltage through this. It didnt change.
                            • jwarnes
                              • Feb 2014
                              • 29
                              If it has to be a zbias fault then what could it be if the dc voltage is correct? A timing issue? Is the zbias voltage a smooth dc voltage or should it be pulsing?
                              • mmartell
                                • Oct 2013
                                • 3189
                                How many ribbons go to the panel from the zsus ? Are they clean and making good contact ?
                                • jwarnes
                                  • Feb 2014
                                  • 29
                                  1 cable and yes i removed it and cleaned it today.
                                  What about one of the driver chips on the back of the z sus board that drive the fets. Could a blown driver chip make it do this problem?
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    What voltage would normally increase when you set the brightness from Standard to High since that may give you a clue as to where the problem is.
                                    • jwarnes
                                      • Feb 2014
                                      • 29
                                      This is my thought also. Today I will test all the voltages and see if any of them change during the menu testing.
                                      • jwarnes
                                        • Feb 2014
                                        • 29
                                        Well i did that test today. None of the voltages change when i change the brightness and contrast.
                                        So im stumped. Anyone???
                                        • themosttogain
                                          HP Envy 13-BA1565na BIOS for potential fix!
                                          by themosttogain
                                          Bit of a weird one here...I have this HP Envy which has an odd fault. Basically the power button doesn't turn the device on. However, immediately after a BIOS reset, it will turn on from battery once, and it'll continue to tun on from mains quite happily, first time every time for a few hours (but will not power on from battery at all). After a few hours, the button will become increasingly unresponsive again even with mains connected. I've replaced the battery, even though there were no signs of a battery problem, and the issue remains. From reading another post on here, the experts were...
                                          07-11-2024, 02:26 AM
                                        • DarkAngelz195
                                          ASUS ROG SCAR 16 (G634J) - intermittent freezing
                                          by DarkAngelz195
                                          Hi guys, this is my first post on here so please be gentle.
                                          I have this ASUS ROG SCAR 16 - G634J laptop that keeps on freezing intermittently, showing a red blinking battery light, resulting in a frozen screen, unresponsive keyboard, only a hard reset will bring it back on. I will say that due to the frequency of it happening now it is really hard to try to load up any monitoring software etc.
                                          Now here is the thing, I have seen at least 5-6 posts around on reddit and ASUS's official forums with individuals all having this exact issue. My bet is that its something to do with...
                                          10-15-2024, 04:43 PM
                                        • themosttogain
                                          HP Envy 13-BA1565na with intermittent power button
                                          by themosttogain
                                          Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                          07-12-2024, 03:03 AM
                                        • Grouickman
                                          Hofmann geodyna 6300 Wheel balancer
                                          by Grouickman
                                          Hi there,
                                          First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                                          Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                                          I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                                          I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                                          03-31-2025, 05:29 AM
                                        • anton brunner
                                          Having a hard time dumping BIOS - Lenovo Ideapad Duet 3 (11IAN8)
                                          by anton brunner
                                          I'm having a hard time dumping the BIOS of a Lenovo Ideapad Duet 3 (11IAN8). The chip is a Winbond W25R256JVEN, directly soldered to the board in a WSON8 package.
                                          Since there are lots of tiny components near the chip, I was hesitant to desolder it using hot air. Instead, I soldered thin wires directly to the chip's pads and connected them to a CH341A programmer (photos attached).
                                          The chip is detected correctly in both NeoProgrammer and ASProgrammer, but I'm unable to get a consistent dump. I've tried over 15 times — shortened the wires to...
                                          05-15-2025, 01:01 AM
