HP Envy 13-BA1565na BIOS for potential fix!
  • themosttogain
    • Jun 2022
    • 43
    Bit of a weird one here...I have this HP Envy which has an odd fault. Basically the power button doesn't turn the device on. However, immediately after a BIOS reset, it will turn on from battery once, and it'll continue to tun on from mains quite happily, first time every time for a few hours (but will not power on from battery at all). After a few hours, the button will become increasingly unresponsive again even with mains connected. I've replaced the battery, even though there were no signs of a battery problem, and the issue remains. From reading another post on here, the experts were suggesting a BIOS issue (which sort of makes sense as the BIOS reset allows the button to work fine for a period) but I have no idea what could have gone wrong to cause that fault. Incidentally, I did udpate the BIOS as part of the diagnosis, and that didn't make any difference.
    I've attached the BIOS dump here...the model is 13-ba1565na, serial no CND1097DOP. Motherboard is a LA-J475P Rev 1.0.
    Any assistance would be greatly appreciated. Thanks!
  • hoaca388
    Badcaps
    • Jan 2022
    • 11807
    Wrong bios chip.
    • themosttogain
      • Jun 2022
      • 43
      Silly me...here's the correct one!!
      • hoaca388
        Badcaps
        • Jan 2022
        • 11807
        HP ENVY Laptop 13-ba1565na Bundle (31Y82EA)
        Serial : CND1097D0P ( zero )
        • themosttogain
          • Jun 2022
          • 43
          Thank you - problem remains with the original battery but seems to work at the moment on the replacement battery. It's very weird...will continue testing and post back in case anyone else encounters the same issue.
          • themosttogain
            • Jun 2022
            • 43
            Fault is still present...as soon as you leave the laptop for more than half an hour, the laptop fails to power on from battery. Sometimes after 20 or so button presses it will come on, and then once powered off again, it will power on again reliably for a few minutes. Then back to the same pattern. I'm fairly certain it's not a physical button thing because like I say, once it's been on, it turns on first time every time...only when left for a while does the problem return. Could this be an issue with the EC BIOS rather than the main BIOS?
            • jackx
              • May 2020
              • 214
              • casa1
              hello
              need fix bios power on off
              hp envy 13-ba1006nk
              id 2R0B1EA#BH4
              CND1342807
                • 21025
                Originally posted by jackx
                hello
                hp envy 13-ba1006nk
                id 2R0B1EA#BH4
                CND1342807
                Off topic, the thread is for the model number in the thread title , 13-BA1565na . Start your own thread.
                • Kenzi
                  Cannot modify HP Envy 15 ep-00008na BIOS
                  by Kenzi
                  I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
                  I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
                  11-09-2023, 05:22 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
                • AustinCER
                  HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                  by AustinCER
                  I currently have an HP ENVY Desktop TE01-1214
                  S/N -
                  2MO22342GX
                  Motherboard - L75365-001
                  BIOS Chip - W25Q128JVSQ
                  Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                  Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                  04-25-2025, 05:56 PM
                • Loki_Fido
                  BIOS request for HP ENVY x360 2 in 1 Laptop 13-bf0002TU PLEASE
                  by Loki_Fido
                  Hi ya folks,
                  Hope everyone's having a good day.
                  I have a HP ENVY x360 2 in 1 Laptop 13-bf0002TU with nothing on the screen.
                  The laptop starts but no display. Connecting to an external monitor give me nothing too. Ive attached my original backup bios
                  Make HP ENVY x360 2 in 1
                  Model 13-bf0002TU
                  S/N CND3171C5T
                  Prod ID 6L2F0PA#ABJ
                  I looked up at this site before writing this request. And there was a link. But i couldn't download any files from it.
                  Any moderator could look it up, if possible? It says, "Invalid file...
                  06-16-2025, 08:02 PM
