Philips 37pfl4606h/12, 5V standby not working
  • BramEPC
    • Feb 2014
    • 5
    • Belgium
    Hi
    I have a Philips 37pfl4606h/12 model that won't turn on anymore (went out with a 'bang' when turning on).
    The cause of the 'bang' was easily identifiable as the TOP264VG was blown up.
    However even after replacing that one (twice, starting to get paranoid :p ) I still do not get a 5V standby.
    In the schematic attached I have already replaced D904, Q906 and Q913 (D904 was necessary if i remember correctly, the other 2 were probably fine)
    I have added my measurements to the schematic, if anyone has an idea how this thing is suppose to work (I assume pin 6 of the TOP264VG should become an AC signal, but it is connected different than in the datasheet) / what could still be wrong ....
    EDIT: The 5V dropping is also DC. It starts at around 5V on power up, but starts lowering gradually...
  • CapLeaker
    Leaking Member
    • 8327
    Re: Philips 37pfl4606h/12, 5V standby not working
    Did you check if the 5VSB rail on the secondary is shorted?
      Also check ZD907, ZD914, R959 IC907, R962.
      • BramEPC
        • Feb 2014
        • 5
        • Belgium
        ZD907 turned out to be the problem, TV works again now
        Thanks a lot for all the suggestions !!!!
        • vinceroger69
          • Mar 2012
          • 6714
          Thanks for the update and glad you have managed to fix your tv.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Well done Budm. Another one saved from the landfill.
              Thanks for the follow-up.
              • xray69x1
                • Sep 2014
                • NETHERLANDS
                thx ! had the same problem. replaced zd907 and top264vg.
                did the job.
                • alro7779
                  Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                  by alro7779
                  Hello, guys!
                  The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                  09-14-2025, 12:25 AM
                • Bad_IC
                  Philips TV 37pfl5604h/12 no standby voltage
                  by Bad_IC
                  I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                  These are the voltages in some pins of IC fsq510:
                  Vcc=18v
                  D=320v
                  Vstr=154v
                  Unfortunately, I couldn't find the schematic
                  What else could I check?
                  Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                  Thank you​...
                  11-08-2024, 01:07 PM
                • jasonbay13
                  Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                  by jasonbay13
                  picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                  am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                  12-01-2023, 09:55 PM
                • zyklop
                  Philips Soundbar TAB8507B/10 stopped working
                  by zyklop
                  Helllo everybody....
                  i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
                  Inbetween it has one time started, but no more yet.
                  Is anybody who has schetatic or service maual ?!
                  Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
                  No thermal hotspots or something else controlled with thermal imaging cam.
                  No reaction on remote control (function ok, can see it while glow into mobile-camera)
                  No shorts to detect.
                  ALso tested all reset procederes...
                  07-07-2025, 05:08 AM
                • Ierwin
                  Philips 58PUS7805 Menu working but no/weird picture from video sources
                  by Ierwin
                  I got a 58pus7805 that shows some weird behavior.
                  The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                  However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                  I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                  I managed to install the latest official firmware by holding the control button while plugging...
                  03-10-2024, 12:50 PM
