Philips Soundbar TAB8507B/10 stopped working
  • zyklop
    • May 2021
    • NRW
    Helllo everybody....
    i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
    Inbetween it has one time started, but no more yet.
    Is anybody who has schetatic or service maual ?!
    Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
    No thermal hotspots or something else controlled with thermal imaging cam.
    No reaction on remote control (function ok, can see it while glow into mobile-camera)
    No shorts to detect.
    ALso tested all reset procederes at startup (+ and power while AC connect), but still no light....nothing....
    any idea ?!
    Greetings
    zyklop
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    I have to find yet a service manual for a sound bar. If it has a OLED display, it might be that. Other than that probably a shorted MLCC somewhere on the board is quite often the cause on these Philips sound bars.
    • StasNep
      Philips HTL6140B/12 SoundBar no power
      by StasNep
      Hello
      I have got a defective Philips HTL6140B/12 SoundBar, no power from button or remote.
      The power supply is external and working correctly, even tried another one.
      Checked caps with esr meter and all seems ok.
      Checked various resistors and smd capacitors and they seems ok.
      Please help to diagnose this SoundBar.
      Thanks ...
      02-20-2022, 10:37 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
    • janos6662000
      Philips 47PFS7509/12 LCD TV problem
      by janos6662000
      Hi
      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
      When i applied cable signal to check image, i had normal picture, but TV was restarting.
      I downloaded original firmware and applied the update, but the problem remained.
      From a colleague i received a "factory package software" which is a lot bigger.
      I made another firmware update, but still did not solve the problem.
      Somewhere on the way the error got worse, because at the moment the...
      08-12-2025, 12:54 PM
