Samsung UE46D6500 black screen no sound.
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    I have a Samsung UE46D6500 that "doesn't boot"(?)..
    First of all, when I unplug main board from power board, back light lights up. Not sure, but I think this eliminates power issues..
    With all connected TV powers on and off and LED blinks pressing sound channel menu etc, either by dashboard or remote.. But it's always black screen (backlights won't turn on) and i ear no sound...
    I took a look over the boards and all I see is heating marks on the board near the DNie CPU.
    Can you help please? Also, if someone has schematics or service manual I'd appreciate it.
    Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    Re: Samsung UE46D6500 black screen no sound.
    Pictures of the board? What DCV testing did you do so far as far as the Voltages and the Command signal Voltages?
    We need more details and pictures.
    • Learn2Day
      • Jun 2013
      • 254
      • Portugal
      Here are some pics of the board. While taking pics I noticed some components might have been removed from main board. This wasn't noticeable at first glance I took, sorry. Tampered solder also in fotos.
      I didn't took voltages because I didn't find any voltage test points on main board, only on power.
      IC1401, IC1205, C751_DS and D704_DS seem to be missing..
      Thanks.
      Try Harder!
        https://www.badcaps.net/forum/attach...5&d=1472832422
        What is the board P/N? BN44-??????
        What DCV do you get on pin 12 (BLU ON/OFF), pin 20 (POWER ON/OFF)?
        So someone try to fix this TV before you?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I assume you bought this tv with this defect?
          There are parts missing on the mainboard so it had a failure BEFORE someone removed the parts. Probably BGA chip failure and he heated the board.
          Wanna fix the tv? Buy a new mainboard and add extra cooling/heatsink plaster and it should be good to go.
            Yep, get the new board.
            https://www.badcaps.net/forum/attach...2&d=1472832422
            So the EEPROM IC1401 is removed, plus other parts.
            • Learn2Day
              • Jun 2013
              • 254
              • Portugal
              Originally posted by budm
              [url]So someone try to fix this TV before you?
              Apparently yes, I bought it to learn, try to fix it and get a "new" TV.
              I might need to buy another main board, right?
              pin12- 0.24
              pin20-5.35
              Try Harder!
                Yep, new main board needed.
                'pin12- 0.24' No backlights on signal.
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  Thanks for the replies. I already saw this replacement on ebay but it's missing one RF input when compared to mine.. Almost all of them are! Will this matter?
                  http://www.ebay.com/itm/Samsung-Main...cAAOSwMgdXxxHG
                  Thanks.
                  Try Harder!
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Its a mainboard for a different model. You need to look for the exact part number on the board.
                    It might work but i Always go for the exact same board. the back cover might not even fit because of the connectors.
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      It's the exact same part number! Bn41-01587e, you can check my first pic
                      Try Harder!
                        Bn41-01587e is the blank PCB as printed with white silk screen, blank board is REV E in this case.
                        The PCBA as printed on the barcode sticker is BN94-05482W.
                        Blank PCB can be stuffed hundreds ways to make a bunch of PCBAs for certain model of TVs required.
                        https://www.badcaps.net/forum/attach...9&d=1472832422
                        I hope that who ever worked on this TV before you did not put the board from other model that uses the same PCB into this chassis.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          As BUDM says. Also on ebay link it says 46inch model from the D6510 series.
                          These boards are in more models but have either a extra USB/HDMI or misses the VGA connector etc. Also firmware is most of the times different.
                          • Learn2Day
                            • Jun 2013
                            • 254
                            • Portugal
                            I get zero results with BN94-05482W either on ebay or aliexpress.. where should i buy this?
                            Try Harder!
                            • Learn2Day
                              • Jun 2013
                              • 254
                              • Portugal
                              I've found a working UE46D6530 with broken LCD for parts.
                              Do you guys think it's possible to get this TV and replace all boards to Get mine working?
                              Thanks.
                              Try Harder!
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                You could try and see if it works. Again its a newer model but it might work.
