cleaning board advice - paintbrush cause static?
  • ocf
    • Jun 2016
    • 157
    I just received a replacement mainboard, seller advertised it as a bit dusty.
    Its caked in old dust and covered in dead bugs, definitely not a state I want to power it on in.
    I only have paintbrushes, I know these can cause static, what do you guys use to brush down boards. I know there are carbon bristle antistatic brushes but I dont have these yet.
    any advice welcome
    edit - title
  • CapLeaker
    Leaking Member
    • 8158
    Re: cleaning board advice - paintbrush cause static?
    I use a toothbrush and 99% alcohol. Never had a problem. So I think as long as your paint brush bristles are made out of nylon, it should be good.
    • ocf
      • Jun 2016
      • 157
      sweet, thanks dude. What is a no go plastic for cleaning? one that does produce static?
      • ocf
        • Jun 2016
        • 157
        I've just read this -
        The amount of static that builds up on your clothes depends on the material and how dry the atmosphere is. All fabrics have some tendency to build up a static charge, but synthetics like nylon, polyester and acrylic are particularly good at generating, and then holding on to, static charge.
        I've also used toothbrushes in the past, in this case its quite a long bristle paintbrush that I will be using thoroughly over the entire board, both sides. Its a TV mainboard and not a power board so higher chance of static damage methinks.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Nylon can create static but I've never had a noticable problem using a toothbrush and alcohol.
          • vinceroger69
            • Mar 2012
            • 6714
            I also use a toothbrush and alcohol and also a paint brush to remove dust from power supplies and mainboards ive never had a problem afterwards.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              I use my air compressor in the garage. Lol
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Screw the haters I have always used a hoover with crevis attachment never had one issue with static at all. So I guess I must be a good ground then ?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Also here the amount of Tv's I have fixed not one issue at all many computers/laptops, xbox's, Psu's etc. Also nearly done 500 Tv's
                  • CapLeaker
                    Leaking Member
                    • 8158
                    I quit counting on what I repaired. :/
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      Thats a fair few repairs reece and you havnt really been doing repairs/sales for long ? and even the best of use gets the odd repair return on us i guess maybe same fault or a different one but its how we deal with the customer that counts, like you say a lot of repairs is word of mouth etc so keeping a good reputation conts in the repair/sales game.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Been doing em 2 years buddy, started in 2014 did board level then 2015 mainly component/board level now I fly through them Also I will admit when I joined bcn I did act very noobish to begin with to test the water I suppose but I have learnt alot off here.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          I like flux brushes..
                          Follow the white rabbit.
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Ive used Any Kind Of Brush closest to me at the time!
                            Paintbrushes, Floor-brushes, toothbrushes--Anything, I aint proud, Never had a problem in 30 odd years!
                            I even soaked a Timebase board in Hot Water for an hour, scrubbed it with dish-brush, and fairy-liquid, swilled off with boiling water, gave it a good shake and dried it in front of a fan-heater for a while.
                            --Looked like new! Oh, It worked just fine too.
                            TELEFIX
                            • CapLeaker
                              Leaking Member
                              • 8158
                              toilet brush?
                              • japlytic
                                • Oct 2005
                                • 2086
                                There are ESD-safe brushes for cleaning dust from boards - you just need to know where to buy them.
                                • ocf
                                  • Jun 2016
                                  • 157
                                  These go on ebay not many UK sellers with them.
                                  I am 99% sure these "antistatic brushes" designed for PCB work are simply carbon bristle brushes the same type used to apply hair dye in salons. They come free with hair dying kits and can be bought for pennies at a hair supplies store.
                                  Just need to get my arse moving and find a local hair supply store.
                                  • rumi409
                                    LG OLED C1 Pixel Cleaning Made Picture Worse
                                    by rumi409
                                    ​​​​​​ Hi,
                                    I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                                    11-15-2024, 01:09 AM
                                  • howardc64
                                    Macbook Dust-Gate Preventive Cleaning
                                    by howardc64
                                    Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                                    Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                                    https://www.ifixit.com/Guide/MacBook...leaning/177920
                                    10-09-2024, 10:10 AM
                                  • claws77
                                    lenovo flex 5 14ITL05 laptop keyboard cleaning
                                    by claws77
                                    are there any resources that talk about cleaning keyboards thoroughly, by that i mean removing keycaps and cleaning.
                                    i am worried about breaking those keycaps or the plastic retainer clip.
                                    08-12-2024, 07:46 PM
                                  • loopster
                                    Need help cleaning ME region on Zbook 17 G1 bios dump
                                    by loopster
                                    Hello guys,
                                    could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                    Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                    I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                    Error 10: Failed to open with processed commands.
                                    Unable to open file: C:\Users\Elitebook...
                                    06-16-2024, 09:57 AM
                                  • mon2
                                    Crate guitar amp with extremely loud static on power on (no input)
                                    by mon2
                                    Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                                    07-18-2025, 06:40 AM
