Toshiba 40E200U1 turn ON but no backlight, no video
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    Power led turn green, but there is not backlight and can't see video in the dark with a flashlight.
    BL-ON: 5v
    Dim, ACD: 0v
    Power ON: 3.6v
    5v: 5v
    12v and 24v: 0v
    I jumped 5v and Power ON nothing, 5v, Power ON and BL ON nothing, Power ON, ACD, BL ON and 5v nothing
    I changed the MB 2 times, with the original the label toshiba in the plastic bezel light up white but not image or backlight, with the second one, not turning on (i assumed is defective) and with the third one turn on, the label toshiba remain off but no video, no backlight.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Toshiba 40E200U1 turn ON but no backlight, no video
    ACD which I believe is AC detect = 0V so there's problably a fault with the power supply and that is why you don't have 12V and 24V. I suspect that the main board is fine.
    Can you locate a manual for the power supply or provide high quaity pictures of the front and back of it .
    Edit
    Check R101, R102, R103, R104 & R105
    • CapLeaker
      Leaking Member
      • 8352
      Jump pson with a 1k resistor to STBY voltage. Do the same with the BLon. Check how much DC V you get on the main filter capacitor. Be careful. Check if the rectifier diodes on the 12V/24V on the secondary are shorted.
      • alfredomfr1
        • Oct 2014
        • 318
        • usa
        I have 167v in each main capacitor
        • CapLeaker
          Leaking Member
          • 8352
          check for VCC on U101. What is printed on U101?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ahh SSI_400_14A01 inverter-I meant shit. Remove/unplug the inverter and see if the set powers up.
            • alfredomfr1
              • Oct 2014
              • 318
              • usa
              CapLeaker: U1 (can't found U101) is a L6571B see picture
              Pin 1: -5.5v
              ReeseyBurger123: With the inverter disconected same no 12v, no 24v
                Pin 1: -5.5v
                What did you use for meter GND to get that - 5.5VDC on the Vs PIN 1?
                Is it really Minus 5.5VDC? can't be right.
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  I did the measure again is something around -9.50v to -10v. Using GND on the board connector and in tv chasis same measure.
                  I did the measure right before send this message and is -4.25v. Crazy !!
                  Note:
                  Multimeter is ok
                  • Diah
                    • Feb 2013
                    • 6594
                    from yours Photo https://www.badcaps.net/forum/attach...6&d=1472422224
                    the Audio Dig Red LED turn On, check your remote control , did the set response for it if not then you have firmware issue eeprom etc,
                    • alfredomfr1
                      • Oct 2014
                      • 318
                      • usa
                      The TV turn ON, is just 12v and 24v are not present, with the inverter connector pluged or not same thing. Im thinking is a power board problem and I need some help to repair the power board
                      • Diah
                        • Feb 2013
                        • 6594
                        you mean when you plug it at wall socket it turn on direct correct ? can you put it in stand by state ? if no then issue as i write before
                        • alfredomfr1
                          • Oct 2014
                          • 318
                          • usa
                          Yes I can turn ON and OFF
                          • Diah
                            • Feb 2013
                            • 6594
                            good in this case you should have picture on screen by dark room and touch light. also what recovery write if you plug out the inverter while set on and back u should have backlight for awhile
                            • alfredomfr1
                              • Oct 2014
                              • 318
                              • usa
                              I didn't see nothing on the screen with a flashlight and will do the plug out test tomorrow but as i write before there is not 12v or 24v
                              • Diah
                                • Feb 2013
                                • 6594
                                if you have not 12 24 v yours tv will never boot and turn on or off.
                                  Note:
                                  Multimeter is ok
                                  You used the wrong GND, when you make measurement in the HOT side, you need to use the negative leg of the main filter cap as the GND ref for your meter.
                                  BTW, is there wire on the ACD pin? This TOSHIBA good ACD signal LOW = Good, right now you have 0VDC so it is OK.
                                  You do have PS-ON signal to turn on the 12V/24V Switched power supply section.
                                  • alfredomfr1
                                    • Oct 2014
                                    • 318
                                    • usa
                                    budm: Using negative leg of the main filter pin 1: -165v
                                    Diah: TV turn on and off perfectly.
                                      MINUS 165VDC? It cannot be MINUS reading.
                                      165V is way too high, the clamping Voltage on that pin 1 Vs pin is around 15V.
                                      Are you sure you are measuring at the correct pin, and measure it correctly?
                                      • alfredomfr1
                                        • Oct 2014
                                        • 318
                                        • usa
                                        I'm agree with you but that's the reading from pin1, thru pin5 = -165v dc
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                          09-06-2024, 05:27 AM
                                        • Boyxba
                                          TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                          by Boyxba
                                          I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                          05-13-2023, 11:47 AM
