Lg 47lv5500
  • Tekone
    • 79
    • united States
    Lg 47lv5500
    Hi, I need some help with my LG 47LV5500 TV, I'm getting power light on from red to white when power on but screen is black. Thanks
  • syaoran123
    • Jun 2014
    • 178
    Re: Lg 47lv5500
    get a hairdryer out and heat the large heatsink on the mainboard for 1-2 minutes. if that helps, you have identified the problem.
    • Tekone
      • 79
      • united States
      Re: Lg 47lv5500
      Hi, thank you very much that work.
      • slickrickybobby89
        • Jul 2016
        • 87
        • america
        Re: Lg 47lv5500
        I have one of these coming today with the same problem, gonna be trying this also.
        • seldomclueless
          • Sep 2016
          • 3
          Re: LG 47LV5500-UA - No Picture, No Sound, Has Backlight
          I have an LG 47LV5500-UA with no picture, no sound. Backlight is working.
          The three fuses on the the Power Supply Board all have 0.0 Ohms across them so are good.
          No burned odor or damaged components are visible on either the Power Supply Board or the Main Board.
          I have not removed the cover from or inspected the TCON board.
          I found the LG 55LW5600 Training Manual on badcaps.net in this forum entry:
          https://www.badcaps.net/forum/showth...light=55lw5600
          I used the LG 55LW5600 Training Manual to verify the following:
          1. I used Test 1 on page 58 of the Training Manual to verify that 24V, 12V and 56V are present as described in the Test.
          2. I used Test 2 on page 59 of the Training Manual to verify that backlight does turn on.
          3. I was able to get 56V on caps C256 and C257 on the Power Supply Board as described on page 62 of the Training Manual. However I am not able to generate 63V at these same locations.
          4. I am not able to use the Tip (second Tip in the bounding box at the top of the page) on page 63 of the Training Manual to force any of the LED blocks on one at a time by grounding EL test points one at a time through a 220 Ohm resistor. I tried this Tip both with and without the jumpers described in Test 1 (page 58) and Test 2 (page 59) installed.
          The set does turn on and off (audible click) using the remote control.
          Model number: 47LV5500-UA
          Main Board: EAX6333405(0) 10.12.16 B.S.W.
          Power Supply Board: TB691621698011485(1.6)
          Since I just joined this forum I am restricted from posting photos of the Power Supply Board and the Main Board. Once these restrictions are lifted I will post high-resolution photos.
          Thanks for your help.
            Re: Lg 47lv5500
            So you have backlights but no plctures on the screen, then you need to find out if you have 12Vdc at both ends of the T-CON fuse with ref. to chassis Gnd.
            • seldomclueless
              • Sep 2016
              • 3
              Re: Lg 47lv5500
              Yes, 12 VDC present on both ends of the T-CON board fuse.
              • seldomclueless
                • Sep 2016
                • 3
                Re: Lg 47lv5500
                Here are high-res photos of the Power Supply Board and the Main Board.
                • ruletero
                  HP Omen only do not turn on, only flashes white light
                  by ruletero
                  Hi everyone
                  Please help me with this laptop
                  HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                  It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                  But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                  Bios was programmed with a working version, no changes.
                  Voltages
                  +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                  06-07-2023, 10:11 AM
                  RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
                  by sam_sam_sam
                  I bought these LED light bars from Electronic Goldmine surplus store online
                  These light bars are the nicest LED light bars I have ever seen in there online store
                  I read the description of these light bars and said yeah right there bright at 9 volts
                  Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
                  But I thought I would give these a try only because they had both light bars on sale as a bundle...
                  02-11-2021, 10:03 AM
                • stevenallauca
                  HP laptop does not charge the battery, the light turns amber and then changes to white.
                  by stevenallauca
                  Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                  - ACN (BQACN) 19.6v
                  - ACP (BQACP) 19.6v
                  - CMSRC (BQCMSRC) 19.6v
                  - ACDRV...
                  09-23-2024, 11:30 AM
                • Ihandyrepair
                  sony 55X850D black screen no front white or red led light.
                  by Ihandyrepair
                  Hi guys
                  strange one
                  I have a dead Sony 55X850D
                  when plug in, black screen, no front white or red LED, no back light no screen
                  Voltages I get
                  3.3v LD/power and main board
                  reg 12V
                  reg 19V
                  3.3v on power on pin
                  no Tcon on
                  no tcon 12v
                  no BL_on
                  I do get BL_ERR 2.0v
                  I tried to bypass it by ground it but still get same symptom
                  I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                  or is possible the chip next to...
                  08-07-2024, 04:58 AM
                • apostsamking
                  latitude 3350 blink 1 white light on
                  by apostsamking
                  Pls I have latitude 3350 laptop and it stop working. I realize that anytime I press the power button it powers on blink 1 white light on and off. I flash bios but the same problem. I realize that the 3.3v that's on the bios chip is not stable. It goes on and off. But when I remove the bios chip from the board power is stable. I have change the bios chip still the same problem. What should I do.
                  05-30-2024, 02:02 AM
