Sony KDL-60ex720 3 blinks
  • dpiroli3
    • Dec 2012
    • 12
    Guys, have a sony kdl-60ex720 that blinks three times. i know the manual says main board but the supply is not putting out 12v to the tcon board or the main board when you push the power button. the high voltage does go from 165 to 300 and nothing seems to be loading down the 12v line. im pretty sure the power supply is bad, does anyone have experience with the aps-299/c power supply? tia
  • Diah
    • Feb 2013
    • 6565
    Re: Sony KDL-60ex720 3 blinks
    do you mean when you measured V. on plug CN6001 only you have PIN 1 no voltage?
    • dpiroli3
      • Dec 2012
      • 12
      im not in front of it now but are you talking about the power on pin having 3,3v? it does and all the other voltages are there except the 12V.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Pictures would be of much help
        • Diah
          • Feb 2013
          • 6565
          and more better when you listed all V measurements after you power on the TV on this socket at BATV
          • dpiroli3
            • Dec 2012
            • 12
            Here is the pic of the supply.
            • dpiroli3
              • Dec 2012
              • 12
              Originally posted by Diah
              and more better when you listed all V measurements after you power on the TV on this socket at PWB
              My board has a 28 pin connector see attached schematic.
              Has 3.3v and 3.3v at power_on when i press the power button, no 12v on any 12v outputs.
              • Diah
                • Feb 2013
                • 6565
                same manual i have.. LOL
                BATV board
                • dpiroli3
                  • Dec 2012
                  • 12
                  i know 3 blinks says its the batv board but why doesn't the 12v come up when the power on input is high on the power supply? i don't want to replace the batv board to find out its the power supply.
                  • Diah
                    • Feb 2013
                    • 6565
                    you still can tested the power board when all sockets disconnected from it and jumper 1KR between standby and power on you will find the 12 volts or not
                    • dpiroli3
                      • Dec 2012
                      • 12
                      Do you know if pfc_on is high or low when the set is in standby?
                      • Diah
                        • Feb 2013
                        • 6565
                        sorry i don't know, maybe other had recorded this measure. to me i interset on the big Cap if it go high or not..
                        PFC_ON & Power_ON both belong to eeprom firmware and the main processor command at socket CN6002.
