repprogram tv firmware
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Question seen a older post about hot to reprogram tv firmware using a usb burner and a special clip. I messaged the guy with no response.
    http://www.ebay.com/itm/181459505516...%3AMEBIDX%3AIT
    I bought that and should be here in 2 weeks. Now I need to know which burner I can use with it.
    My ultimate goal is I usually buy broken tvs to sell parts on ebay. What I want to do is capture all good firmware from Vizio. And then I will release it on the net for those who need it.
    I also want to use the firmware to try and fix a couple boards. From my understanding of the post, a lot of the Vizio firmware is the same through out the model tvs. So instead of buying a replacement chip, just burn new firmware on fixing any corruption. And then I should be good.
    I would appreciate letting me know which burner you guys are using.
    http://www.ebay.com/itm/USB-Programm...wAAOSw3ydVkT51
    I see that one, but not sure if it would work or not. This is a new realm for me. Most I ever did is hot flash bios chips back in the day. But actually this would come in handy since a friend of mine bricked his board in a bios update. And this clip would work with that chip!
  • tw2005
    • Oct 2011
    • 6458
    Re: repprogram tv firmware
    That should work. You just need to identify the type of chip and set it up accordingly as the pin outs are different between type 24 & 25.
    The clip maybe turn out to be a bit crappy, that's what I found with mine. You can get a 3M or Pomona SOIC8 clip but the prices were not cheap.
    I purchased something similar and the cabling broke, then the pins did not make good contact but managed to get it a few times. Alternative is to desolder and solder the IC to a test board.
    I had some fun with it. I got it so I could convert Panasonic A boards more easily to a different model.
    I also restored a 1 blink no starting Panasonic to working as it was corrupted firmware. I enjoyed that and also doing a comparison dump to known good firmware to find a single character changed.
    https://www.badcaps.net/forum/attach...8&d=1454727751
    http://www.ebay.com/itm/Pomona-5250-...YAAOxyvuVSHUOT
    http://www.ebay.com/itm/3M-SOIC-8-pi...AAAOxyFrNRuQme
    • ozzy214
      • Nov 2013
      • 319
      • usa
      Ok but what burner did you hook it to? Thats my question
      • tw2005
        • Oct 2011
        • 6458
        Did you not post a second link to a CH341A eeprom programmer?
        Mine was a green one. That's all I needed, plugged it into the laptop, loaded the drivers and software and that was it , read, write, erase, etc.
        • tw2005
          • Oct 2011
          • 6458
          This looks similar, all same really at this price
          http://www.ebay.com/itm/10Pcs-CH341A...cAAOSwubRXGdN6
          • ozzy214
            • Nov 2013
            • 319
            • usa
            Ok ya thats what i ordered, Good to know it will work. Can you tell me how to assembkle it?
            • jason123
              Vizio D50-F1 - Can't update Software / Firmware
              by jason123
              Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
              I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
              I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
              08-15-2021, 06:48 AM
            • Lee M.
              Vizio E55-DO firmware corrupted?
              by Lee M.
              I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find...
              04-02-2023, 03:12 PM
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
