Sony KDL-46VE5 - no power, no standby or LED
  • RyanM
    • Oct 2018
    • 3
    Re: Sony KDL-46VE5 - no power, no standby or LED
    Originally posted by dick_barton
    Have you checked the resistors identified above?
    Is the resistor built into the main board? Which part might it be?
      See post #5 to see what the resistor looks like, it is on power supply board.
      The question is, what is the TV/ Boards not doing?
      What kind of testing have you done and did you read the whole thread?
      • RyanM
        • Oct 2018
        • 3
        That's what I thought. I just wanted to make sure before tearing it open. Nudged it a tad and TV turned right back on. Thanks!
        • gintama
          • Sep 2007
          • 59
          One more saved from the landfill sounds good to me.
          • adster
            • Oct 2019
            • 3
            Just reporting another 45VE5 saved by this thread. It had sat around for a good year or more and I just cracked it open and found no standby power and everything dead on the power board.
            Found this thread and went straight after that RY6000 relay and found that holding it down while plugged in turned on standby power which then made the power switch work and the TV fired right up.
            Cleaning the relay didn't help anything and I couldn't find my soldering iron so I just used electrical tape to hold the relay down for good. I tested it with the kill-a-watt and found the draw on standby with the relay held down is ~0.5 watts. If this doesn't hold I'll do the bypass fix posted above but I believe taping it accomplishes the same thing.
            Anyhow, thanks for the good work above guys!
              • 12187
              • U.S.
              #26
              So the problem is a bad relay then, correct?
              • adster
                • Oct 2019
                • 3
                Not necessarily, I think it could also be a resistor or something that energizes the relay. I'm not the best with electronics troubleshooting at this level so I didn't go much farther than what's in this thread.
                Seems like a common issue though, never would have got it without this thread.
                  If R6016 is open then there will no Voltage to feed the bridge rectifier D6000 so there will be no standby Voltage, the relay is used for bypassing the resistor when TV is turned on because you do want to have 6.8 Ohms resistor in series with the load, in standby the resistor does not dissipate much heat but when TV is on then resistor will dissipate lots of heat that is why it is bypassed by the relay.
                  If you want to bypass the relay contact you can just bridge the two solder pads of the relay contacts, no need to cut any trace and reroute the Hot and Neutral traces which is not a good idea.
                    • 12187
                    • U.S.
                    #29
                    Thanks Bud.
                      "because you do want to have 6.8 Ohms resistor in series with the load"
                      Correction, it should be 'you do not want'.
                      • adster
                        • Oct 2019
                        • 3
                        Great, thanks! My electrical tape fix didn't hold up, so ended up just bridging the relay pads as you suggested. Back up and running for good.
                        Just out of curiosity, I was wondering what the point of this circuit is in the first place, if bypassing it causes no problems?
                        • renee
                          • Jun 2010
                          • 21
                          #32
                          please help me to find volts PRI_VCC on C6206 sony G6 power supply
                          • R_J
                            • 9535
                            Originally posted by renee
                            please help me to find volts pri_vcc on c6206 sony g6 power supply
                            Why ask on every thread, start your own thread
                            • Equilibrium
                              Old Member
                              • Nov 2013
                              Just to let you know that your modification saved another Sony KDL-46VE5
                              I cut the trace and added the 2 jumpers on the power board and now it REVIVE !
                              A big thanks to you.
                              I found this TV on my street, saved from the trash.
                              Have a nice day
                              Originally posted by gintama
                              Well, this project sat on the workbench long enough, here is the final outcome.
                              I found multiple places that still had stock of the needed power PCB, most at a cost of USD ~$100 with shipping to Canada. Most had exactly the same quantity available, so were probably just storefronts with the same supplier. My friend wasn't sold on putting that much money into an old TV and possibly still ending up with it not working, so I proceeded with my earlier plan.
                              The lower trace to CN6003 (the Energy Saving Switch) was severed, and a jumper was added to connect that point to one of the relay contacts (RY6000, just above the "R"). The upper point of CN6003 is already connected to the other relay contact. Finally, a jumper was connected between the two nearby test points, JL6523 & JL6524 to replace the switch.
                              When the Energy Saving Switch is ON, the TV's standby LED comes on and the unit behaves as expected. When the switch is OFF, there's no standby power and the remote cannot turn on the TV. Once the TV is turned on, the relay closes normally, so you could move the switch to the OFF position and nothing would happen. Power usage appears unchanged, about 3W in standby regardless of the position of the switch. The switch itself is sort of redundant in this configuration, but I thought it best to have a way to bypass the hack in case the unit is left unattended for a long period of time but not unplugged.
                              • R_J
                                • 9535
                                This is not the way to repair this problem, Just replace the open R6016 resistor and relay.
                                • gintama
                                  • Sep 2007
                                  • 59
                                  #36
                                  End results, though.
                                  After six more years of service, the original device was retired. While the screen was still good everything else was failing - audio output full of static, all digital inputs dead, needed an HDMI-to-composite converter to use it at all, video signal would drop out after being used for a few hours.
                                  I suspect the power supply but no time to dissect it.
                                  • Tomcat_STL
                                    • Oct 2023
                                    My 2009 KDL-46W5150 crapped out just as I was trying to re-home it. No Power, No click, No nothing.
                                    I want to thank you for the insight to fix the TV. Mine has an APS-247 Power Supply. Sure enough, the 6.8ohm cement in-rush resistor was open. I had a 50W 6.0ohm power resistor which I jumpered across the open one. The rest of the TV is fine.
                                    Neither the exact relay or resistor appear to be available. Therefore, I bought a new Power board for about $35. Waiting on it to arrive.
                                    Thanks Again to you & budm!
                                    • Tomcat_STL
                                      • Oct 2023
                                      The open resistor on my APS-247 Power Board.
                                      and the offending relay..
                                      • rabbituk
                                        Sony HCD BX7700dbi CMT flashing standby
                                        by rabbituk
                                        I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                        So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                        02-11-2025, 05:05 PM
                                      • androripara
                                        Sony Bravia 55HX820 - 4 times blinking red standby led
                                        by androripara
                                        i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                        I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                        Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                        10-19-2023, 05:16 AM
                                      • denisten
                                        Sony STR-DB870QS standby transformer
                                        by denisten
                                        Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
                                        04-14-2023, 03:24 AM
                                      • Carlos#2003%
                                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                        by Carlos#2003%
                                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                        02-15-2024, 07:52 PM
                                      • SkishyIshy
                                        Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                        by SkishyIshy
                                        Hey All,
                                        I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                        I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                        I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                        03-17-2021, 11:44 AM
