Toshiba 46rv350u No backlight, No picture but has sound
    Re: Toshiba 46rv350u No backlight, No picture but has sound
    can you check PFC driver IC Q860A for shorts as ive read this can blow fuse f820 too
      Did you download the diagrams in post #10.
      You need to check for shorts:
      D809
      D820 PFC
      Q820 PFC
      Q821
      Q860 SMPS
        Give me a few to check. thanks
          D809
          D820
          Q820
          Q821
          Q860
          yes downloaded and printed a few sections
            D809 no short
            D820 PFC no short
            Q820 PFC no short
            Q821 no short
            Q860 SMPS some pins have continuity with each other. I have no idea if thats normal and do not know how to test this part correctly
              what is the part number of the ic at q860 then we cah get a data sheet i think its a STR-Z2589 8208 if so theres a data sheet in post 14 of this thread https://www.badcaps.net/forum/showthread.php?p=661588
                str-z2589
                  q860 PICTURE
                    as per budms advice in the thread ive posted the link for maybe test this
                    OK, the only load for that F820 fuse is that STR-Z25XX series, so the internal short may be half of the bridge drive power MOSFETs may be shorted out.
                    You need to check the resistance between pin 5 and pin 1 (for the upper MOSFET), then pin 1 and pin 21 for the lower MOSFET to see if one of them is shorted out or has very low resistance. Make sure you count the pin correctly.
                      pin 1 and 5 133 ohms
                      pin 1 and 21 14.8 m ohm
                        actually i am getting odd reading on pin 1 and 21 starts off at 7 m ohm and drops down to around 3 m ohms
                          my guess is ic is bad lets see what budm says before you order one and another resistor
                            luckily r850 didn't blow this time, I have an extra one also just incase.
                              now pin 1 and 5 read .402k ohm
                                maybe remove the ic and retest?
                                  I'll have to wait until my new solder sucker comes in for removal, mine just died out. I'll get back Monday or so whenever it comes in.
