Sceptre 409BV-FHDU8HJ1L02 dead
  • bigmatt0211
    • Dec 2015
    • 44
    Hello all, my Sceptre cut out on me :/. I don't get anything. No lights, power, nada. I'm fairly competent with electronics, but have no idea where to start with TVs. Anyone willing to help me get this thing back up and going? I'd lvoe the opportunity to learn about it. I've attached the pictures of the two boards.
  • brucetv
    • May 2015
    • 281
    • united states
    Re: Sceptre 409BV-FHDU8HJ1L02 dead
    Take your DMM and provide us with the voltage readings at CN5/6 and others. Also check voltage at main filter cap. Check all fuses and esr's on the 6 caps on the power supply and let us know what you find.
    • bigmatt0211
      • Dec 2015
      • 44
      So, looking at my DMM, I realize I don't have capacitance measurements. Will that be a problem?
      I don't seem to get any voltage on cn5/6 or any other of the wires leading off the board. I tested them with a wire poking each one (while the connecter was still on it). The voltage across the main cap is 166.5v. I will get the other caps in the morning.
      Thank you for your help so far!
      • bigmatt0211
        • Dec 2015
        • 44
        So, I am having a hard time getting any measure on those other caps. It seems they are sitting at 0. Maybe C62 - the little black one on top, maybe is 3.7 mV. The main cap also seemed to drop the longer it's plugged in.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          With the power supply disconnected from the mainboard what voltages do you have at the connectors.
          • bigmatt0211
            • Dec 2015
            • 44
            Ok, after disconnecting the power and letting it sit overnight, I measured the voltages across each of those connectors. The only one that had anything was the NC connector which ranged around 2.5mV - 13.3 mV. All of the others were 0.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Using your meter set to dc volts can you carefully measure the voltage between the two legs of capacitor C64.
              It's on the live side of the mains supply so be careful taking the measurement.
              • bigmatt0211
                • Dec 2015
                • 44
                So, right now I am getting nothing. I measured with two different DMM. When I measured it earlier in this post, I had 166.5V.
                So partial side story, when I was getting the measurements, I had the power board on its side. I guess I pushed it a bit too much, and something grounded with the back of the tv (i think). There was a spark and the fuse to the room popped.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  Pity since all the measurements could have been done from the top of the board with it still in place.
                  • bigmatt0211
                    • Dec 2015
                    • 44
                    Yeah, true. I was checking for solder issues and measuring some of the other caps. So, what are your thoughts?
                    • slickrickybobby89
                      • Jul 2016
                      • 87
                      • america
                      If you shorted the board there are more than likely more blown component's than what you were originally dealing with, i would suggest replacing that board completely with a replacement from shopjimmy.com or ebay, depending on availability, but you may also want to consider a new set, as there is a possibility that when you grounded the live board you may have damaged something else other than the power supply. And replacing multiple boards can get costly.
                      • slickrickybobby89
                        • Jul 2016
                        • 87
                        • america
                        I recently repaired this same exact power supply and my issue was blown mosfets, check the pins @ q12 q11 & q6, look for a short between the 3 pins at each location.
                        • bigmatt0211
                          • Dec 2015
                          • 44
                          Ok, so, I replaced the power supply. Success... sort of..
                          It worked for a night just fine. I thought I was in the clear, but the next day, we were watching it and the screen turned off, though we still had sound. I unplugged it, plugged it back in and had image again. However, after we turned it off that night, it hasn't given me an image back. I still have sound, but the screen wont turn on.
                          Think you could help me troubleshoot this?
                          • cliff_hootarski
                            • Jul 2006
                            • 411
                            With the TV "On", shine a bright flashlight onto the screen and see if there is a faint image displayed on the screen.
                            • bigmatt0211
                              • Dec 2015
                              • 44
                              There was nothing that I could see.
                              • bigmatt0211
                                • Dec 2015
                                • 44
                                Any other ideas?
                                • CapLeaker
                                  Leaking Member
                                  • 8018
                                  I think you have to explain much better what your issue is. No image... what do you mean? Are the backlights out? With everything plugged in and TV running, check the BLon and adj pin on the PSU.
                                  When you turn the TV on, do the backlights come on for a second and then shut off? Do that in a dark room, or look into the vents on the back of the TV.
                                  What does the LED indicator on front of the TV do?
                                  In other words, you either got a main board problem (EEPROM) or a backlight inverter problem. For shits and giggles, freeze the EEPROM on the mainboard with a can of air upside down and turn the TV on. I think I gave you enough for now on your "To Do List".
                                  • bigmatt0211
                                    • Dec 2015
                                    • 44
                                    Cool, thanks. I will do that tonight. Just a little more background - The tv had sound, but no image. I checked with a flashlight, but didn't see anything. The front led does change from red to blue when I press the power on.
                                    I'll let you know the results of that stuff tonight.
                                    • bigmatt0211
                                      • Dec 2015
                                      • 44
                                      Hey good news I think. I believe it is the backlight now. I was able to see the Sceptre logo on startup when I had a light on the screen.
                                      • CapLeaker
                                        Leaking Member
                                        • 8018
                                        now you measure the DC V on the BLon pin.
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
